Old 03-28-2024, 05:46 PM   #1
3W Hank
Default Magneto and belts
I think I might made a misstake with my set-up on wateter pump belt and a magneto.
Block is 59BA.
Generator is a 37 on a PM intake.
Crank pulley, dont know but I think seller said it was a dual now cutted and will work to generator.
Waterpums its just mock-up and pulley is rather tight but I’m not shore if its 59BA or 8AB.
Cam cover is 8AB so magnet is a early Scintilla but lower part is for the 8AB.
I had the idea to get a 3-bolt cam cover and angle adapter but I realise it would be very hard on both short and the longer adapter and a fan ( ex 32 ) no matter of angle on magneto ( did not like electrical fan )
I did try to seek on Hamb ’wanted’ on both angle adapter and a magnto but not much calls ( junk ) or Very expensiveeven tuff shape.
So one day I came over the magneto for a resonable price and a nice tag but it was foot for a 8AB.
But magneto was burned so Cirello in LA has now fixed it, so with a NOS cap, NOS pointers, cam cover and all car time ( cost ) and freights, repairs its now a expensive unit. I guess way over 2K in it.
But I mock it upp fast here and where belt is there the magneto body.
It must be impossible with this set-up of pulley ( or ) ?
I thought this was the ’easy’ way, not as cool as a angle drive.
Hard to get pictures but here is the set-up.
Ideas how to solve this.
3W Hank is offline   Reply With Quote
Old 03-28-2024, 06:10 PM   #2
petehoovie
petehoovie's Avatar
Default Re: Magneto and bets
The only thing nice about being imperfect is the joy it brings to others....
"Silver rings, your butt! Them's washers!"
"We shot our way out of that town for a dollar's worth of steel holes!" - from 'The Wild Bunch' - 1969
https://www.youtube.com/watch?v=7NReUd2_0u0
Old 03-28-2024, 06:44 PM   #3
kurt v
a front view would help
kurt v is offline   Reply With Quote
Old 03-28-2024, 08:33 PM   #4
Ronnieroadster
Ronnieroadster's Avatar
You need to use 8BA style water pumps and crank pulley when your using that type of front cover. Use Ford flathead truck F-1 water pumps their mounts will match the early water pumps you have in the photo.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 03-28-2024, 08:36 PM   #5
Bored&Stroked
Bored&Stroked's Avatar
The problem is you can't run a late distributor/magneto off the timing cover and still run the early 37-48 water pumps and crank pulley. When they moved the distributor to the side in 49 - 53 they also changed the crank pulley and the water pumps (along with the timing cover cam/crank gears, etc). The later water pumps put the belts further away from the block - such that there is room for the belt to go by the distributor. You could make the front of the motor "act like a 49-53 - with the later crank pulley, water pumps, etc.. That is what Ronnie is talking about . . . but that brings in another whole set of issues (depending on the frame/year you're putting this into).
Also, you have to think about your generator and fan - your setup will not work with the belts being moved further forward (using the late F1 water pumps) - so there is another problem.
So, if you're putting all of this in a stock 32 frame, you just created a big problem --> the crankshaft pulley now wants to be in the middle of the front cross-member. Some folks "jacked their engines up" - but that looks like crap. So, if you're putting this in a 32-34 frame and want the engine in the stock location . . . you're kind of hosed. You really need to go back to a front-mount ignition (angle drive magneto, crab distributor, etc). There is no room for the later crankshaft pulley - with the engine in the correct location. Hell, there is barely room for a single-sheeve crankshaft pulley in the stock location!
Also, you probably don't want to move the engine back - then you have firewall and a host of other issues (think transmission location, clutch location, etc, etc, etc.).
Old 03-29-2024, 07:14 AM   #6
3W Hank
Ok.
A question.
I has invested to much effort in the 8AB set-up so I cant build the case on try use a 38 generator and a std 32 fan.
But…if I found a doubble crank pulley and use the RT pumps can I use the inner to generstor and outer to pumps.
Would that work.
Or try to use a smaller pulley to bend the belt around the lower part of magnet (?)
Old 03-29-2024, 07:38 AM   #7
3W Hank
Like this, a extra tension wheel move away the belt from mag.
Old 03-29-2024, 08:31 AM   #8
Tim Ayers
I still don't think that is going to clear, but the only true way to know is to mock it up. Use a rope to simulate the belt
Old 03-29-2024, 08:43 AM   #9
cadillac512
cadillac512's Avatar
Like this? Works...keeps the belt below the base of the Chevy distributor. The belt tends to crack after about 6-7000 miles with the reverse bend around the pulley.
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 03-29-2024, 09:16 AM   #10
Bored&Stroked
Coming up with a solution to re-route the belt could still allow you to run the rest of the necessary early water pumps, early crank pulley, etc.. If you're willing to make parts and customize how the belts work, then you should be able to solve the problem.
Having big-bends in these ole' v-belts will shorten their useful life, but who cares (just keep a spare in your truck). Given all the belt bends - that is why the automotive world went to serpentine belts many years ago.
Also, you should be able to run the 32 fan in the stock location (on the generator) - which makes the whole setup a LOT easier to do (in a 32 - 34 chassis). You'll also be able to use the stock 32 motor mounts - which is a big plus if you have a stock front cross-member. (with just a bit of clearancing for the later 37 -48 belt angles).
Old 03-29-2024, 09:20 AM   #11
Bored&Stroked
Yeah, something like that should work. The fan setup scares the heck out of me - especially from the perspective of balance and wobble. I sure wouldn't be running it at the RPM that I tend to do in my 32! LOL
Old 03-29-2024, 10:34 AM   #12
3W Hank
Well I like the idea rew 6K..but a fan blade made 1932 and some rust tension in the rivets, jepp not the best idea in the world !
I will never in reality do a burnout with this car ir rew 6K.
But I lathed a mock up tension pulley at OD 2.5” and it look like this.
It will clear.
But how belt tension will be here I has not yet figure out.
Note, the magnet will go down more, as Ciirello made a new longer axle so I can has the steady rest in the cover.
( I need ream up hole some )
Old 03-29-2024, 10:49 AM   #13
cadillac512
The fan setup is stock 1941 Mercury crank driven. Henry probably didn't approve of hot rodders like you! LOL
Old 03-29-2024, 11:48 AM   #14
petehoovie
petehoovie's Avatar
It will clear.
Old 03-29-2024, 12:24 PM   #15
Bored&Stroked
I know the crank pulley is stock . . . is that long extended fan also stock? I've never built a flathead/car of that year.
Old 03-29-2024, 12:25 PM   #16
Bored&Stroked
It will clear.
The belt tension is set by raising/lowering the generator (where the fan will also mount).
Old 03-29-2024, 01:16 PM   #17
cadillac512
Yes, it is. Seems crazy doesn't it?
Old 03-29-2024, 01:21 PM   #18
3W Hank
Its not that uncommon to use a stock 32 fan on a older generator in a 32 chassie as I understand it.
I heard of 32 wings has fly out cars on hwy…
But my is in a very nice condition, not pitted.
I was just try to give this issue a sololution.
Shore I can bought RT pumps but that get me change the idea on the generator/fan.
It also look better with belt closer to block ( my opinion )
I got a pretty straight line.
But it might be needed move out the water pump pulley atleast some, so my bet it will be RT pumps.
Old 03-29-2024, 01:24 PM   #19
petehoovie
petehoovie's Avatar
I heard 32 wings has fly out cars on hwy…
I was jusg try give this isdsue a sololution.
Shore I can bought RT pumps but that get me change the ide vs geberator/fan.mit skso look better with belt closer to block ( my opinion )
Old 03-30-2024, 06:56 AM   #20
3W Hank
Default Re: Magneto and belts
Anyone know this company is still fix pumps ?
I need get the pulley out some to clear the covers.
http://www.fordcollector.com/water_pumps.htm
