08-03-2020, 06:33 PM | #1 |
Mounting new tires on freshly painted wheels
Just had my wheels painted Tacoma Cream and need to mount new tires on them. Anyone know any tricks/tips on what to do so they won’t be scratched or chipped?
Thanks |
08-03-2020, 06:48 PM | #2 |
Re: Mounting new tires on freshly painted wheels
How we did our wheels recently was get a moving blanket and two blocks of wood to lay the wheel on. That way you won't scratch it and you are able to access the other side.
"The more things change, the more they stay the same." |
08-03-2020, 07:04 PM | #3 |
Check your "Private Message" in the upper right corner of this web page.
Marshall |
08-03-2020, 07:25 PM | #4 |
08-03-2020, 07:58 PM | #5 |
08-04-2020, 11:44 AM | #6 |
08-04-2020, 12:44 PM | #7 |
I have heard of using trash bags to protect the wheel as you are mounting the tire.
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 1979 MGB -Life's Too Short To Drive Boring Cars- |
08-04-2020, 01:14 PM | #8 |
See attached article.
Tom Endy |
08-04-2020, 06:36 PM | #9 |
08-05-2020, 05:14 AM | #10 |
08-05-2020, 04:44 PM | #11 | |
Neat video thanks for posting. He was sure quick. Can you imagine the carpal tunnel these guys had to suffer from for using their hands and wrists like that all day long? John Deere outsourced tire mounting at the factories years ago, because so many guys were having carpal tunnel issues it was tearing them up. |
08-05-2020, 05:22 PM | #12 |
Gee, that was easy!
08-07-2020, 09:43 AM | #13 |
I am due to paint my 19” rims, how about info to take tire off, or should I bring to a recommended tire store who is familiar...
08-07-2020, 12:18 PM | #14 | |
I did this and it worked great. Sent from my iPhone using Tapatalk
-Noah 1931 Model A Pickup My Model A : http://www.fordbarn.com/forum/showthread.php?t=173024 |
08-07-2020, 02:04 PM | #15 |
08-07-2020, 10:35 PM | #16 |
The best way to change a tire is to build a platform using 2X4 and plywood. Cut out the center so you can lay the wheel hubcap side down and remove the tire from the back side. Cover the platform with a carpet. I used indoor out door carpet.
Break the bead on the front and the back of the tire. Place a plastic garbage bag over the rim and tuck the bag into the tire. Use a small tire iron and I use a piece of hard plastic to protect the paint on the rim and then work the tire off the rim. Remove the inner tube and repeat the process to remove the tire from the rim. To install the tire place the plastic bag over the rim and work the tire onto the rim, this can be done by hand but if you need to use the tire iron and the piece of hard plastic to work the tire on the rim. Remove the plastic bag, install the inner tube. Place the plastic bag over the rim and work the plastic bag between the tire and the rim and work the tire onto the rim, this can be done by hand, or your foot. If you need to you can use the tire iron and the piece of hard plastic to work the tire on the rim.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
