Old 01-16-2018, 05:00 PM   #1
Ford1930
Ford1930's Avatar
Default LED lights for drum type rear lights?
Are there any LED's for the drum type rear lights of the Model A?
Ford1930 is offline   Reply With Quote
Old 01-16-2018, 05:59 PM   #2
1931 flamingo
1931 flamingo's Avatar
Default Re: LED lights for drum type rear lights?
I think I saw them in Snyder's catalog I was flipping thru last night. FWIW
Paul in CT
Old 01-16-2018, 06:48 PM   #3
SeaSlugs
SeaSlugs's Avatar
I thought there was at one point...
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 01-16-2018, 07:06 PM   #4
Synchro909
Synchro909's Avatar
Even if the replacement lenses aren't available, how would LED globes go in the standard light?
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-16-2018, 07:09 PM   #5
SeaSlugs
SeaSlugs's Avatar
probably terrible since theres hardly any reflector to speak of (not to mention the STOP insert blocking light as well)
Old 01-16-2018, 08:18 PM   #6
Dutie
Dutie's Avatar
Yes there are LEDs for the drum style rear lights. There shaped to fit the light in two halves, one on top and one on bottom and they set in and are supported by soft sponge. They are big improvement...good luck dutie
Dutie is offline   Reply With Quote
Old 01-16-2018, 08:19 PM   #7
SDJason
SDJason's Avatar
I switched over to these (I've got 6V, all red) and couldn't be happier - VERY bright compared to bulbs, and they draw much less current as well.
Here's the post I made when I switched over - it has "before" and "after" pictures which help show off the brightness difference.
SDJason is offline   Reply With Quote
Old 01-16-2018, 08:38 PM   #8
Wick
Wick's Avatar
If you have changed over to 12v just go to Walmart and pickup a 2pk of led bulbs. $14.95
I've done this to my vw and camper.
Wick is offline   Reply With Quote
Old 01-16-2018, 09:34 PM   #9
briphaeton
Thanks SDJason but yours aren't the drum style tail light. I installed led lights like yours in my 1930 and love them (all red ones)
Brian
briphaeton is offline   Reply With Quote
Old 01-19-2018, 05:07 PM   #10
Ford1930
Ford1930's Avatar
Dutie. Where can I buy them???
Old 01-19-2018, 08:27 PM   #11
jm29henry
jm29henry's Avatar
Brattons I have them in mine no alterations just plug in
jm29henry is offline   Reply With Quote
Old 01-19-2018, 08:57 PM   #12
wingski
wingski's Avatar
I have them in my ’29, and they are much better than regular incandesent bulbs. My car is 12 volt, but even with 6 volt there has to be a big difference. They just twist in like the other bulbs. I would think that NAPA would carry them. I have no idea about how long they last. Maybe forever, but I highly doubt that.
Mike
wingski is offline   Reply With Quote
Old 01-19-2018, 09:27 PM   #13
SteveB31
SteveB31's Avatar
We have them. $7.50 each. Part # A-13465-L. They work in any tail light or brake light socket. Very bright.
Bert’s Model A Center
SteveB31 is offline   Reply With Quote
Old 01-19-2018, 10:09 PM   #14
Dutie
Dutie's Avatar
Hello 1930, they came from Brattons. Did not know for sure how they were going to look as my top half drum glass is amber but somehow they show up nice and red, the whole light. Nice and bright and low voltage, can barely see the amp meter move when brake light is on. Good luck Dutie
Old 01-19-2018, 10:18 PM   #15
Franchise_24
Franchise_24's Avatar
https://www.brattons.com/6-vt-driver...ail-light.html
This is what I use on my '28 Leatherback and they work great! I was especially happy to get them since I just have the one tail light.
1929 Model A Ford Coupe
Franchise_24 is offline   Reply With Quote
Old 01-20-2018, 05:11 PM   #16
Jim/GA
Jim/GA's Avatar
Or get them here (even though it says they won't work on a drum style tail light, they are the same ones that Bratton's sells which do work on a drum):
https://www.snydersantiqueauto.com/led-lamp-kits
Use some of the bubble wrap with the very small diameter bubbles wadded up and inserted behind the green printed circuit boards to hold the LEDs up tight to the back side of the lens and they work great!
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 01-20-2018, 09:10 PM   #17
JohnLaVoy
JohnLaVoy's Avatar
The lens replacement hasn't been done yet. I spoke to United Pacific and they don't see enough need to make up that lens.
JohnLaVoy is offline   Reply With Quote
