Old 10-19-2021, 10:54 AM   #1
bavArian
bavArian's Avatar
Default Gas gauge gasket disintegrated
Hello everyone,
now that the roadster is registered and street legal I have the first few problems:
1) Is it normal that the speedo cable has to be inserted in the speedometer first? If I insert it into the drive on the torque tube first it's too short to drive the speedometer. (I'll see if it keeps in place or falls out of the speedo after the first few rotations tomorrow)
2) The gas gauge was rebuilt around 2 and a half years ago. After filling it up completely today I noticed a leak on the gas gauge. After draining 1/4 of the tank and disassembling the gas gauge I found that the cork gasket is completely gone, only small crumbs are left. Has that happened before?
My guess is that it's the darned ethanol fumes in the fuel. Do the neoprene gaskets work better?
Thanks and have a nice day,
Daniel
bavArian is offline   Reply With Quote
Old 10-19-2021, 11:42 AM   #2
sinbad339
sinbad339's Avatar
Default Re: Gas gauge gasket disintegrated
This is the reason I try to only use 100% gasoline (no ethanol). The alcohol dissolves the cork.
"Our times are characterized by a perfection of means and a confusion of ends." - A. Einstein
sinbad339 is offline   Reply With Quote
Old 10-19-2021, 12:26 PM   #3
J Franklin
J Franklin's Avatar
The gasket mostly likely succumbed to old age. The cork gaskets are the best in this application.
Old 10-19-2021, 12:45 PM   #4
bavArian
bavArian's Avatar
I used new gaskets 2 and a half years ago and they were not NOS ones.
I'll try the neoprene ones, ethanol-free gas is not really an option because that's around 1,929 € per litre / 8,50 $ per gallon.
Normal gas is "only" 1,669 € per litre / 7,36 $ per gallon.
Old 10-19-2021, 02:27 PM   #5
Big hammer
You'll be changing the neoprene gaskets sooner than the cork gaskets.
get a bigger hammer tap done
Old 10-19-2021, 02:47 PM   #6
Keith True
Keith True's Avatar
If you install new cork gaskets and don't get them wet with gas in a couple of months they can disintegrate.I mostly find the quality of the cork is the biggest problem.Also,people will buy a gasket set and let it set around for a year or two before installing.I have two cars that have had the guages swimming around in alcohol for over 30 years.Probably longer,I did the guages in the early 80's,and a local station has been selling gas with alcohol in it since about 1980.It was marketed as gasohol in the early years,or at least until everybody else had to sell it.Then the name was dropped.
Keith True is offline   Reply With Quote
Old 10-19-2021, 05:30 PM   #7
J Franklin
J Franklin's Avatar
Use the cork gaskets. Some use a smear of grease on them to ease install and maybe it helps preserve them a bit.
Old 10-19-2021, 06:27 PM   #8
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Cork gaskets and neoprene float seems to be the magical combination.
Ivan in southeast va. is offline   Reply With Quote
Old 10-20-2021, 04:46 AM   #9
jerrytocci
Trying securing speedo cable to frame and firewall last
jerrytocci is offline   Reply With Quote
Old 10-20-2021, 11:02 AM   #10
bavArian
bavArian's Avatar
Thanks for your replies.
Here's a small update:
The speedo works, but above a certain speed the speedo starts jumping and there's a loud buzzing/grinding sound coming from directly below the seat. I'm assuming that it's the speedo drive housing. It's slightly cracked so I assume the resistance from the speedo pushes the housing outwars just a bit, resulting in the gear grinding over the worm gear in the torque tube.
Removing the speedo cable solves that, so I'll order a new housing among some other parts while the car is in hibernation.
The gas gauge got a makeshift repair with liquid sealant because I don't have the gaskets stocked. I'll order new cork gaskets and coat them with gas resistant sealant before installation. That way they should last longer than the last one.
On top of that I lost almost all power today after a short trip at about 50 mph. Turns out that it wasn't a hanging float like I'd assumed (that has happened the first day after a sharp and fast left turn) but the small bakelite plate that opens the points-finger. Almost completely sheared off, it probably got brittle with age and just broke off. After trying to fix it with what I had with me (and failing miserably), I screwed the contact point all the way in and limped back home in 3rd gear at low revs. But at least I made it back without a trailer, so that's still something positive.
Total statistic so far:
Runtime: ~4 - 5 hours over 3 days
Traveled distance: ~ 34 mls
Number of breakdowns: 2
Number of curses: 0 (a wonder! )
Lessons learned: Keep the tools in the car and ALWAYS carry some duck tape.
Have a nice day,
Daniel
Old 10-20-2021, 11:07 AM   #11
J Franklin
J Franklin's Avatar
When you replace the points smear a bit of points cam lubricant on the cam. Maybe even buff and polish the cam to make it less abrasive on the point block.
Old 10-20-2021, 11:57 AM   #12
bavArian
bavArian's Avatar
Good idea. The surface of the cam looks quite smooth but I'll polish and lubricate it when I have a new set of points.
Old 10-20-2021, 11:57 AM   #13
Y-Blockhead
Y-Blockhead's Avatar
I use Cork/BUTA-N gaskets in my gas cap, carburetor, sediment bowl and gas gauge. Never had a problem with ethanol.
Old 10-20-2021, 12:30 PM   #14
john charlton
john charlton's Avatar
If the car is RHD the speedo cable is routed differently to LHD . The cable runs up through a slot in the toe board so is a shorter route . I have my LHD cars routed this way less bends . If you have a regular rear end 3.78 and need a 9/34 cap I will mail you one for free you pay postage . PM your address .I am in England not too far .
John in no change in location or weather
john charlton is offline   Reply With Quote
Old 10-20-2021, 12:37 PM   #15
hardtimes
hardtimes's Avatar
Originally Posted by bavArian View Post
Hello everyone,
Daniel
I just rebuilt my gas gage… with neoprene gasket.
I tightened by hand (OLD hands). Let it be for weeks and then re- tightened with tool. Seemed to need re-tightened for sure !
hardtimes is offline   Reply With Quote
Old 10-20-2021, 10:40 PM   #16
bavArian
bavArian's Avatar
Thanks for your offer John, but I have to make an order in the states anyway because there are a few parts that I need. So I can just put the speedo-parts on the list.
How can I check what rear end I have? Turn the engine a few revolutions and see how far the rear wheels turn?
If possible I'll compare the speedo with a modern car in the next few days, then I know if the speedo drive is the correct one. That would also tell me the rear end ratio, correct?
Old 10-21-2021, 05:42 AM   #17
john charlton
Your speedo drive cap will be marked on the "bump" if you have the standard 3.78 rear end it will be marked 9/34 . The vendors only sell this ratio cap and it is way more likely you have the 9/34 . Order plenty of gaskets you adjust the gear mesh with these and can use up to three sandwiched . Adjust so you have a little slack ,no play is no good . Order to suit your speedo cable flag or square end .It could be your noise is the cap is on too tight .
John in same place same weather .
Old 10-21-2021, 06:20 AM   #18
Oldbluoval
Oldbluoval's Avatar
On the gas gauge..
Be sure and use the very thin brass washers as original. These let the nut slide on the gasket without crinkle or damage
Oldbluoval is offline   Reply With Quote
Old 10-21-2021, 06:43 AM   #19
Marshall V. Daut
Check your "Private Messages" in the top right corner of this webpage.
Marshall V. Daut
Old 10-21-2021, 09:05 AM   #20
Big hammer
What is your source for the cork/BUTA-N gaskets? Please and thank you!
