10-25-2014, 12:25 PM | #1 |
Lil Regulator assistance please
I needed a new regulator for my tractor, the only 12v regulator in stock at NAPA was a VR428
The wiring shows it to be I terminal for ignition A terminal for the battery S terminals for stator F terminal for field As my tractor has a generator, I assume I connect my armature wire to the S-stator-terminal on the regulator? The VR428 is a replacement for Ford Alternator regulators, just verifying it will be okay with my generator. Thanks |
10-25-2014, 12:35 PM | #2 |
Re: Lil Regulator assistance please
There are 2 different types of generator fiels setups--one makes a ground for the fiels, the other adds power for the field --different regulators that won't interchange---and using the wrong one can damage both generator and regulator
the other job of a regulator is to protect the generator from overloading itself and burning up (amp regulation) this has to be matched to the generators max safe output A regulator for an alternator won't work for a generator |
10-25-2014, 12:37 PM | #3 |
I see, thanks Kurt...will take it back.
10-25-2014, 03:58 PM | #4 |
Not sure what you have in your area, but Tractor Supply Company (TSC) carries a lot of tractor parts as do other farm supplies. You could most likely order a part online and have it two days.
10-25-2014, 04:11 PM | #5 |
Geesh, I didn't even think of TS...and my sister works there!
10-25-2014, 05:07 PM | #6 |
10-25-2014, 05:32 PM | #7 |
Massey Ferguson 203...distant relative to a Ford
10-25-2014, 07:44 PM | #8 |
10-25-2014, 09:47 PM | #9 | |
