08-03-2015, 07:47 AM | #1 |
clutch shaft arm change
My mongrel 32 Tudor has a 59AB, with 37 trans. and what I thought was a 37 x-member. Turns out that the x-member is a 34.
If I use the 34 pedal setup, do I need to change the throwout arm to 34 (longer and offset) to have the correct lever ratio? Seems like I do. Thanks! |
08-03-2015, 10:06 AM | #2 |
Re: clutch shaft arm change
