11-13-2013, 11:00 AM | #1 |
Evap-O-Rust Problem
A couple of years ago I started soaking my shocks in Evap-O-Rust. In the midst of this is when my daughter Jessica became ill and put us on a 10 week tour of hospitals. I had been soaking them two by two in a plastic coffee can and putting them under the bench overnight and rinsing them the next day. Needless to say in the cloud of smoke and confusion we left in, I forgot about them. Last night while doing more cleaning in the shop I opened the coffee can and there they were covered in thick sticky goo that to this point will not simply rinse off. Does anyone know what will take the dried on goo off at this point? Any fail safe ideas are welcome. Thanks Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!! |
11-13-2013, 11:47 AM | #2 |
Re: Evap-O-Rust Problem
Running warm water and a fingernail cleaning type brush.
11-13-2013, 11:48 AM | #3 |
Did you try soaking for a couple of days in fresh evap-o-rust?
Short URL: http://smu.gs/14g7eDW |
11-13-2013, 11:53 AM | #4 |
I would try the hot soapy water and brush first.
11-13-2013, 12:11 PM | #5 |
Hi Rowdy,
POR 15 "Marine Clean", is a water based product which some may think it is too expensive; hence, maybe why few try it. However, if you do not have time to mess around with scrubbing with other cleaning products, get a gallon from someone like Snyder's for cleaning all types of Model A crud. When diluted I can usually make about 4-5 gallons of cleaning solution which will last a long time for Model A use. Strongest solution I make is usually in small batches of one (1) part MC to four (4) parts "hot" water with water taken from hot water faucet. Solution stays hot & does not cool off in small batches. Cleans "any" & "all" petroleum base product even those as thick as tar or gum. I know castor oil & milk of magnesia works for humans, but I'd hate to see someone take a teaspoon of MC as a laxative -- in my humble opinion, one may lose 75 - 80 pounds with a one (1) teaspoon dose of MC. LOL Hope this helps. Last edited by H. L. Chauvin; 11-13-2013 at 12:15 PM. Reason: typo |
11-13-2013, 12:54 PM | #6 |
11-13-2013, 01:22 PM | #7 |
11-13-2013, 04:33 PM | #8 |
Thanks guys, will see if I can find their number. Other than getting it rised off I hope the shocks are not badly damaged as if memory serves me correctly those were 2 of the covers that were correct for my delivery sedan. Rod
11-13-2013, 08:06 PM | #9 |
That really sucks, keep us posted on your findings and best of luck!
11-13-2013, 08:53 PM | #10 |
I had a similar fubar with some shock arms that I forgot about. Evaporust and the like under different names avidly supports growth by microorganisms. In fact, what often kills its' derusting action is contamination by bacteria which eat it.
So any cleaner high in phosphate or perhaps even better ammonia that will dissolve organic residue may be of help in cleaning. What shocked me was the additional corrosion, to the point where one arm was almost severed, occurred where two arms touched each other. Apparently I made a destructive battery; hopefully your covers fared better. |
