02-18-2022, 03:34 PM | #1 |
29 Model A Coolant
So after my deal with the leaky carb, it runs and doesn't leak but needs coolant, which is the best coolant to put in it. Thanks
02-18-2022, 03:38 PM | #2 |
Re: 29 Model A Coolant
50/50 green antifreeze
02-18-2022, 03:54 PM | #3 |
Autozone Brand fine?
02-18-2022, 04:02 PM | #4 |
Walmart 50/50 @ $7.89 a gallon is good stuff also.
02-18-2022, 04:34 PM | #5 |
Cheapest you can find.
02-18-2022, 04:43 PM | #6 |
old ugly my old father-in-law told me. "listen close when people tell you how to do stuff they may know something. then do it the way you want." |
02-19-2022, 07:38 AM | #7 |
A lot of Model A engines have been compromised by running straight water. It rusts the insides of the engine and will freeze and crack blocks. The antifreeze will restrict rusting. The green stuff will wear out in a few years and needs to be replaced then. Take the old antifreeze to a radiator shop to be disposed of properly. If you are running an aluminum head use a zinc.
02-19-2022, 12:29 PM | #8 |
02-19-2022, 01:00 PM | #9 |
02-19-2022, 03:41 PM | #10 |
FWIW,
I read somewhere that the newer antifreeze formulas were acidic?? and could cause problems in the A's system. The thread said all Prestone brand antifreeze were this way. I found some green antifreeze that said on the label for all older cars before 1995.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!" |
02-19-2022, 04:35 PM | #11 |
Rob, does that mean Sierra? I used to use Sierra. It does not foam. You can't use a standard antifreeze tester in it though, and that scares me. I want to know how far down I am protected.
02-19-2022, 05:46 PM | #12 |
Zerex Original Green. $9.00 a gallon at NAPA for the concentrate. You add your own water.
02-19-2022, 06:28 PM | #13 |
I used premixed from Autozone.
02-22-2022, 12:18 AM | #14 |
Make certain to use distilled water.
Retired civil engineer. Winters in Phoenix, summers in Ipswich, Mass. and North Dakota. '29 closed cab pickup- Excellent AZ truck. '29 roadster- Owned for 21 years but now sold. '28 CC pickup- My first car in Andover, MA back in '62- '63. |
02-22-2022, 12:27 AM | #15 |
Why do you say distilled water. As a young lad I worked at service stations and car dealerships and we filled the water can from the hose.
02-22-2022, 05:12 AM | #16 |
Wayne, hose water will work, but if you want to keep impurities out, use distilled water.
Brass copper etc all eventually "rot" from impurities in the water. |
02-22-2022, 07:52 AM | #17 |
02-23-2022, 01:36 PM | #18 |
It’s my understanding, that distilled water is hungry water, so it draws minerals out of the block. I believe I read this on one of the water wetter sites. They did not recommend distilled water. I don’t know, maybe this is like oil.
02-23-2022, 03:53 PM | #19 |
I use Prestone Lotox. Pet friendly and doesn't hurt the paint. Win! Win!
02-24-2022, 12:05 PM | #20 |
I'm like Hep1966, premix 50/50 from AutoZone or Advance, with distilled water to top off if need be. But I remember my Dad just using the garden hose on his A's including the one I have, so go figure...
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 1979 MGB -Life's Too Short To Drive Boring Cars- |
