Old 01-10-2012, 02:42 PM   #1
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Default 1931 Running Board picture(s) wanted
Does anyone have any pictures of an original 1931 running board that they would be willing to share with me. While I am interested in the top side too, I am most interested in the bottom side as I am comparing some details. Thanks!!
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 01-10-2012, 02:50 PM   #2
Doug in NJ
Doug in NJ's Avatar
Default Re: 1931 Running Board picture(s) wanted
Do you need to see the rubber or trim, or just the underside sheet metal??
Doug
My '31 S/W sedan project:http://31ford.dougbraun.com
My restoration diary: http://dougbraun.com/blog
Doug in NJ is offline   Reply With Quote
Old 01-10-2012, 02:59 PM   #3
BRENT in 10-uh-C
My main objective is the bottom side at this point however I would like to see some details like corners of rubber, etc.
BRENT in 10-uh-C
Old 01-10-2012, 03:23 PM   #4
Aerocraft
Aerocraft's Avatar
Here are a few pictures of the right running board of my April 1931 40B. The car is low mileage and has never been restored or taken apart. Ask if you need more. Gar Williams
Aerocraft is offline   Reply With Quote
Old 01-10-2012, 04:15 PM   #5
Marco Tahtaras
Marco Tahtaras's Avatar
Unfortunately I never took any overall photos and currently have them packed away.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 01-10-2012, 04:20 PM   #6
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
Marco, do you also have any pics of the same of 29 boards.....thanks
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 01-10-2012, 06:07 PM   #7
Midwest Tin
Midwest Tin's Avatar
Mark, Check your PM. Jim Sinclair
Midwest Tin is offline   Reply With Quote
Old 01-10-2012, 06:11 PM   #8
Midwest Tin
Marco, Are the 31 boards NOS and if so what is the original underside finish like. Do they appear dipped or spray painted after the rubber was installed?
Thanks, Jim Sinclair
Old 01-10-2012, 07:49 PM   #9
BRENT in 10-uh-C
See, that is what I am finding is some seem to have that reinforcing strip down between the two brace mounts, ...and some don't. I guess I need to look at the prints but until then, is there anything significant to that reinforcing strip??
BRENT in 10-uh-C
Old 01-10-2012, 10:39 PM   #10
Doug in NJ
Doug in NJ's Avatar
Interesting: My '31 running boards have a reinforcing rib running along the bottom, but yours do not.
Also, I see that hex-head bolts, not carriage bolts, were used to connect the running board to the front fender. The Hardware Guide (and the vendors' bolt kits) say that carriage bolts were used, but my fenders and running boards had perfectly round holes, and there was no way carriage bolts could have been used there.
Are the bolts between the fender and splash shield hex or carriage? My car seemed to have all hex, but I could not be sure they were original.
Thanks,
Doug
Old 01-10-2012, 10:46 PM   #11
31Tudor
31Tudor's Avatar
Doug, The three bolts securing the running board to the front fender were hex heads, the two securing the rear fender to the running board were carriage bolts. The splash pan to fenders were hex bolts front and back.
31Tudor is offline   Reply With Quote
Old 01-11-2012, 01:07 AM   #12
Marco Tahtaras
Hi Jim,
Yes, they are NOS. I attempted to capture the appearance in this pic below. It looks like a VERY thin coat of rubber leaving a somewhat mottled appearance. It could possibly be paint but I haven't yet been inclined to test it with chemicals to determine for sure.
Old 01-11-2012, 01:17 AM   #13
Bill in SoCal
Bill in SoCal's Avatar
Default reinforcing strip
I have an early 30 coupe. The running boards have the reinforcing strip down between the two brace mounts. It looks like it was intended to reinforce that area of the running board.
Bill in SoCal is offline   Reply With Quote
Old 01-11-2012, 11:55 AM   #14
BRENT in 10-uh-C
Default Re: reinforcing strip
Aren't your '30 running boards different that these?
BRENT in 10-uh-C
Old 01-11-2012, 12:16 PM   #15
Modelakid31
Send a message via AIM to Modelakid31
I have noticed the late 31's are the ones that have the reinforced strip.
Modelakid31 is offline   Reply With Quote
Old 01-11-2012, 01:39 PM   #16
Bill Underwood
I sold a pair of NOS with the original Vicky sold to DAvid Moore. They had mould numbers, etc. I saw nothing on them like what Marco is showing for data. They were painted with a brush because you could see brush swirls. The medium looked as if it were a very light pitch or asphalt base material, dull. See if David can supply pics. I think he put them on the car.
Bill Underwood is offline   Reply With Quote
Old 01-11-2012, 08:46 PM   #17
Midwest Tin
Marco, Thanks for your reply and photo. Jim
Old 01-12-2012, 12:02 AM   #18
Bill in SoCal
Default 1930 Running Board picture(s)
Brent, Are we talking about the reinforcing brace between the two support brackets? Like in these pictures? Bill
Old 01-12-2012, 12:21 AM   #19
Marco Tahtaras
Default Re: 1930 Running Board picture(s)
Brent was only interested in the late '30 and '31 boards which are entirely different.
Old 06-22-2012, 06:45 PM   #20
oldmanandakid
oldmanandakid's Avatar
A little off topic but does the welt material go between the ends of the fenders where they attach to the fenders?
oldmanandakid is offline   Reply With Quote
