Old 08-12-2020, 10:43 AM   #1
johnbuckley
johnbuckley's Avatar
Default Clutch pressure plate New or Reconditioned?
Time for a new clutch pressure plate . Snyders has a choice of brand new ones A-7563-X at $110 OR reconditioned original ones A-7563-OR ( no exchange needed) at $150 . Has anyone had experience of which may be better. ( it's not worth me shipping a core across the Atlantic )
johnbuckley is offline   Reply With Quote
Old 08-12-2020, 10:50 AM   #2
Dick M
Dick M's Avatar
Send a message via Yahoo to Dick M
Default Re: Clutch pressure plate New or Reconditioned?
Bert's Model A Center has a pressure plate rebuilder. He does a great job. The fingers are preset so all you have to do is bolt it to the flywheel. Steve at Bert's told me he has not had a defective rebuilt pressure plate come back in 30 years. I have one on my A. Five years and 12,000 miles later it still working perfectly.
Dick M is offline   Reply With Quote
Old 08-12-2020, 11:51 AM   #3
1930artdeco
1930artdeco's Avatar
The new ones have (to me at least) dodgy workmanship. I bought a new one and when I got it, I looked at it and sent it back. It had multiple washers used as spacers.
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 08-12-2020, 12:26 PM   #4
Purdy Swoft
Purdy Swoft's Avatar
I use rebuilt pressure plates and new disk . I have bought rebuilt model A pressure plates at such places as NAPA and other local parts stores . They probably won't have them in stock but can get them PDQ . A trade in core will be required .
Old 08-12-2020, 01:06 PM   #5
fuzes45
New ones made in China. Junk
Bob
fuzes45 is offline   Reply With Quote
Old 08-12-2020, 01:20 PM   #6
Ruth
Go rebuilt. I hear the new ones have issues. Bratton's does not even sell new ones anymore.
While on the subject of clutches, I get my clutch disc from Bratton's Their disc has the incapsuled springs (see picture) while other vendors do not.
Ruth
Old 08-12-2020, 01:25 PM   #7
dennis lumbert
dennis lumbert's Avatar
I have a new one that I installed with my AER rebuilt engine 2100 miles ago . It has functions perfectly so far .I used a new disc from Berts and adjusted the pressure plate fingers at install.
dennis lumbert is offline   Reply With Quote
Old 08-12-2020, 02:30 PM   #8
Tom Endy
Tom Endy's Avatar
See attached article.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 08-12-2020, 02:42 PM   #9
Los_Control
Whats involved in rebuilding a pressure plate? working on newer 1951 8BA
Seems to me resurface it, new springs and adjustment. Is this something a guy can do at home? Can we buy replacement springs?
Some of us who work on these old cars like to do everything we can ourselves.
possible op may do same?
Los_Control is offline   Reply With Quote
Old 08-12-2020, 04:36 PM   #10
1930artdeco
I found a spring shop that can sell me the different springs for the pressure plate (Model A). I would have to check my emails for the name. surfacing might be a bit problematic unless you have a large lathe to do it right.
Mike
1957 Country Sedan
Old 08-12-2020, 07:18 PM   #11
chrs1961815
chrs1961815's Avatar
Don't forget about balancing.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-12-2020, 08:36 PM   #12
Mulletwagon
Mulletwagon's Avatar
I may be the exception but had a bad experience with the encapsulated style disk. The disk shown is a heavy duty disk which if normally used in truck applications. One would think it should work fine in car applications and probably does for most. The PO of my 31 Tudor installed the heavy duty disk with a V-8 style pressure plate. The chatter was extremely bad and the PO said it just needed adjustment (which I doubted). The heavy duty disk has heavier springs and what seems like a harder friction material. I tore it all down and could not find anything wrong or out of spec. I elected to put in a standard duty clutch disk with the lighter springs and unflanged spring retainers and all chatter was eliminated. Thinking maybe the heavy duty disk is not completely compatible with the V-8 pressure plate. Like the retained springs but the chatter just rattled my fillings too much. Maybe its just my unique experience.
Mulletwagon is offline   Reply With Quote
Old 08-12-2020, 08:37 PM   #13
RonC
RonC's Avatar
www.fortwayneclutch.com reman Model A pressure plates.
Get your clutch disk from brattons they sell disks with spring guards.
Send them your brattons clutch disk and they will set the fingers to your disk
RonC is offline   Reply With Quote
Old 08-13-2020, 12:27 PM   #14
Jim M
Jim M's Avatar
x2 for Bert's. I opened the box and did not have to do a thing. Put it in and still perfect!! Highly recommend Steve.
Jim M is offline   Reply With Quote
Old 08-13-2020, 03:18 PM   #15
RandyinUtah
I spoke with Steve owner of Bert's last year with the same question ( new or rebuilt) he informed me his rebuilder was no longer and only had new clutches. Perhaps Steve will post with updated information on this subject.
RandyinUtah is offline   Reply With Quote
