Old 10-21-2022, 05:04 PM   #1
imacrazy
Default leak in steering box
What is the best way to stop a leak in the steering box.
Thanks Bill
imacrazy is offline   Reply With Quote
Old 10-21-2022, 05:53 PM   #2
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Default Re: leak in steering box
If it's a small leak, try pennrite steering grease.
Ivan in southeast va. is offline   Reply With Quote
Old 10-22-2022, 07:08 AM   #3
1931 flamingo
1931 flamingo's Avatar
X2 !
Paul in CT
Old 10-22-2022, 07:21 AM   #4
29spcoupe
29spcoupe's Avatar
John Deere corn head lube works great too.
29spcoupe is offline   Reply With Quote
Old 10-22-2022, 07:39 AM   #5
Big hammer
No OO grease for me, just repaired my two tooth gear box after trying OO and 600W mix. Steering was ok before but leaked, I’am thinking the grease couldn’t get to the sector bushings and then got so tight it took two arm’s to turn. I used a new sector housing with the roller bearings, now two finger steering (rolling down the road) IMHO a leaking gear box is better than OO grease in a gear box…….or rebuild your gear box.
get a bigger hammer tap done
Old 10-22-2022, 10:00 AM   #6
Dino's A
Dino's A's Avatar
STP works good as well.
Dino's A is offline   Reply With Quote
Old 10-23-2022, 10:35 PM   #7
31a
Tried the cornhead grease later when I rebuilt the box did not feel like it did a good job went back to heavy weight
31a is offline   Reply With Quote
Old 10-24-2022, 07:00 AM   #8
Robert/Texas
Robert/Texas's Avatar
I have Pennrite in four of my old Fords. No leaky and easy steering. Pricy but the one bottle still has enough left for another car.
Robert/Texas is offline   Reply With Quote
Old 10-24-2022, 10:30 AM   #9
Y-Blockhead
Y-Blockhead's Avatar
Pennrite Steering Box Lube and an "O" ring (https://www.snydersantiqueauto.com/p...7909&cat=41749) on the sector shaft seemed to work for me.
Old 10-24-2022, 11:56 AM   #10
RoadsterJohn
RoadsterJohn's Avatar
https://www.snydersantiqueauto.com/p...7901&cat=41748
Worked for me.
RoadsterJohn is offline   Reply With Quote
Old 10-24-2022, 02:46 PM   #11
duke36
Can you isolate where the leak is coming from ? Sometimes the large gasket between the mating surfaces doesn't seal.
Old 10-24-2022, 03:11 PM   #12
DBrer
I Use Pennrite, works great for me.
DBrer is offline   Reply With Quote
Old 10-24-2022, 03:45 PM   #13
aermotor
Do you have the steering housing end plate with tube?
aermotor is offline   Reply With Quote
Old 10-24-2022, 04:27 PM   #14
nkaminar
nkaminar's Avatar
The plate with the tube that RoadsterJohn has a link to.
Fix the leak then use 85W-140 gear oil. The modern oils have additives that will extend the life of your steering box and make it easier to turn. Do not use grease because it will get pushed out from between parts causing them to run dry and will not get into the bushings.
