Old 03-28-2024, 02:57 PM   #1
65f100
65f100's Avatar
Default 48 ford
where would i find the serial/vin# - 1948 ford 4 door sedan
65f100 is offline   Reply With Quote
Old 03-28-2024, 02:59 PM   #2
65f100
65f100's Avatar
Default Re: 48 ford
Old 03-28-2024, 04:02 PM   #3
FortyNiner
FortyNiner's Avatar
Default Re: 48 ford
For vehicles produced in the US, on the top of the driver's side frame rail between the radiator support and the steering box. The stampings are not deep, so use a scotch-brite pad to remove the typical crud as you search.
Old 03-28-2024, 05:05 PM   #4
petehoovie
petehoovie's Avatar
Default Re: 48 ford
Originally Posted by 65f100 View Post
Old 03-28-2024, 06:23 PM   #5
19Fordy
19Fordy's Avatar
Default Re: 48 ford
This will help: Same as a 47 Ford
http://www.vanpeltsales.com/FH_web/1...eardown-13.htm
Old 03-29-2024, 10:01 AM   #6
65f100
65f100's Avatar
Default Re: 48 ford
very god thanx for replies!..Ill look there again when its off the trailer and remove front clip
Old 03-29-2024, 10:19 AM   #7
TJ
TJ's Avatar
Default Re: 48 ford
Most often I have found that the 46-48 Ford ID number is found near the front crossmember.
