Old 03-27-2024, 10:57 AM   #1
91A-77B
Default Leaking Head Studs
I recently had my 59A completely rebuilt. Block was baked, magnafluxed, etc. When I first fired it up, several of the head studs were dripping coolant. After running, I re-torqued the heads (vintage Navarros with dead-flat decks) 3 times @ 45#. I now have 3 that keep on dripping after about a total of one hour running. Questions: is this normal? Should I keep running it and hope they'll somehow seal themselves up? Should I pull the studs and re-seal? Any other ideas? Thanks for your help.
91A-77B is offline   Reply With Quote
Old 03-27-2024, 11:01 AM   #2
Kube
Kube's Avatar
Default Re: Leaking Head Studs
Was there any type of thread sealant applied to the studs when installing them to the block?
I believe most of us apply our favorite sealant in that area.
Usually, the small leaks will stop on their own. If not, adding a block sealant that remains in motion (unless needed in a specific area) will most certainly do the trick.
I have used Alumaseal, an aluminum-based powder, with very good results.
Old 03-27-2024, 11:14 AM   #3
richard crow
when the warm weather comes run the car on water in rad. they will stop
richard crow is offline   Reply With Quote
Old 03-27-2024, 12:31 PM   #4
deuce_roadster
deuce_roadster's Avatar
What Kube said x2.
Old 03-27-2024, 02:35 PM   #5
Ronnieroadster
Ronnieroadster's Avatar
Sodium Silicate will seal them perfectly as well AKA Water Glass once the water temp reaches 140 degrees.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is online now   Reply With Quote
Old 03-27-2024, 08:32 PM   #6
v8fordman
v8fordman's Avatar
Thread sealer would have solved the problem but most likely after a few heat cycles, it will stop as Kube stated.
v8fordman is offline   Reply With Quote
Old 03-30-2024, 06:49 AM   #7
91A-77B
Thanks for your advice, guys. I drained the coolant and refilled with distilled water, then put in a bottle of 2-part Rislone Cooling System Repair, and ran it for about 15 minutes. In all the books I've read, and rebuilders I've talked to, I never heard of leaking studs. And thanks to CharlieNY for explaining why it happens.
Old 03-30-2024, 10:48 AM   #8
Shoebox
Shoebox's Avatar
"I drained the coolant and refilled with distilled water, then put in a bottle of 2-part Rislone Cooling System Repair, and ran it for about 15 minutes."
So, are we to assume this fixed your issue, just asking?
I went, I saw, I bought the T shirt
51 Ford Deluxe Tudor
32 Ford roadster
39 Mercury Towncar
Shoebox is online now   Reply With Quote
Old 03-30-2024, 01:18 PM   #9
91A-77B
Hope so, Shoebox. A bit early to say. I'll run it a few more times before inserting it into my 37, and report back to you guys who were good enough to send your suggestions.
Old 03-30-2024, 04:40 PM   #10
Bored&Stroked
Bored&Stroked's Avatar
I use a water-glass type product as Ronnie mentioned. I buy Moroso Ceramic-Seal . . . getting it from Jegs. You must follow the instructions and use clean water. If your engine already has anti-freeze, then you'll need to go back to straight water - and I'd "rinse it through" a couple times - before using the ceramic seal. Also, drain the ceramic seal as they recommend - right after you get done with the running of the engine.
Old 03-31-2024, 10:29 AM   #11
alchemy
alchemy's Avatar
Many references to guys retapping the stud holes to “clean” them when rebuilding engines. But the holes are built with a tighter tolerance than the taps used, and are as such opened up too much. A source of this weeping.
alchemy is offline   Reply With Quote
Old 04-03-2024, 05:35 PM   #12
91A-77B
Tanks again, all. I'll give the Rislone a while to do its thing. That failing, I'll follow other suggestions you've made.
