Old 04-01-2024, 05:16 PM   #1
KenBolton
Default New Coil in Script Can
I’ve been told and have read this can be done. I’d like to see some photos of how to do this. I have a script reproduction which failed. I took it apart and tried to insert a new coil. It enters the lip that held the backlit top but will not enter the can. Are original coils slightly larger in diameter?
KenBolton is offline   Reply With Quote
Old 04-01-2024, 05:41 PM   #2
AL in NY
AL in NY's Avatar
Default Re: New Coil in Script Can
KenBolton: when you gutted the aftermarket script coil, did you end up with one layer of metal or two. I tried the same thing last summer and was unable to separate the two layers of metal, which made the ID too small to fit over a newer standard style coil.
At the Hamilton MARC meet, I picked up an original/OEM script coil which I also gutted. Unfortunately, it was still too small to fit over a newer standard style coil even thou it had only one layer a metal.
Five years ago, I did the exact same thing with an original/OEM script coil and it DID fit over a Pertronix epoxy coil. Maybe I was just lucky!!!!
AL in NY
AL in NY is offline   Reply With Quote
Old 04-02-2024, 10:48 AM   #3
katy
katy's Avatar
Were all the "original/OEM script coils" made by the same manufacturer?
katy is online now   Reply With Quote
Old 04-02-2024, 11:54 AM   #4
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
No. Autolite, Bosch, Essex, and Standard were the most popular manufacturers for Ford.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 04-02-2024, 03:15 PM   #5
KenBolton
There was a shorter metal layer inside the can. It pulled right out with needle nose pliers. I do have an original script coil that is still good so hate to tear it apart. Can anyone answer my question of whether the original can diameter is larger than the repos?
Old 04-03-2024, 09:11 AM   #6
katy
katy's Avatar
Can you not just measure your "original script coil"?
Old 04-03-2024, 09:42 AM   #7
alexiskai
alexiskai's Avatar
I think he means the internal diameter.
Old 04-03-2024, 02:51 PM   #8
John
John's Avatar
I too would like more information on gutting an original coil to install an aftermarket coil in the body. Any pictures or "How To Do" would be greatly appreciated before I begin this project.
Thanks,
John
John is online now   Reply With Quote
Old 04-03-2024, 07:58 PM   #9
katy
katy's Avatar
Would have helped if the PO had said ID or OD.
