Old 03-19-2024, 08:57 PM   #1
Randall
Randall's Avatar
Default 255 Merucry Dyno Pull
Finally got the mercury flathead done!
https://youtu.be/--sgJpT6m7U?si=wI_9ia9iSQLKNmM9
Randall is offline   Reply With Quote
Old 03-19-2024, 10:48 PM   #2
oldbugger
oldbugger's Avatar
Default Re: 255 Merucry Dyno Pull
couldn't read the results, interested because thats the same motor i have in my 35
oldbugger is offline   Reply With Quote
Old 03-19-2024, 11:04 PM   #3
Newc
Newc's Avatar
Speak more clearly and eunciate your words- so many folks slur their speaking. Video and phones do not carry words well generally. Newc
Newc is online now   Reply With Quote
Old 03-20-2024, 12:15 AM   #4
GB SISSON
GB SISSON's Avatar
Looks to me like the first run had a max of 129 hp and the secong 126.So it's stock, other than the cam? What is the bore now? I had no problem understanding the narative. I think he just has one of them Southern accents. Thanks for posting that.
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 03-20-2024, 05:15 AM   #5
Tim Ayers
Randall,
That's awesome and thanks for sharing. Can you tell us a little more about what you did? 126 hp is impressive for a stock looking motor.
Old 03-20-2024, 05:32 AM   #6
Ziggster
Thank you for posting! So few vids on YT of actual dyno tests of flatheads. Eventually I want mine dynoed. Mine (C59A) is completely stk with only a 0.060 overbore and Pete’s Isky 1007B cam grind. I was thinking mine might come in at around 110-115 hp. Also good to know that the 4,000 rpm tach I have is all the rpm’s I’ll need to measure. Lol!
Ziggster is offline   Reply With Quote
Old 03-20-2024, 07:24 AM   #7
jimTN
Good job Randall!!!
Old 03-20-2024, 07:48 AM   #8
deuce5wndw
deuce5wndw's Avatar
Good job Randal! I had no problem with the accent maybe because we sound alike!
deuce5wndw is offline   Reply With Quote
Old 03-20-2024, 08:09 AM   #9
Bored&Stroked
Bored&Stroked's Avatar
I had no problems with the video - understood everything. In looking at Dyno pull #2, the engine is either breaking up due to the ignition or floating the valves at about 3800 RPM. Both torque and HP bounced around and fell right off. Given this is in a stock type application, it is a good running engine.
Old 03-20-2024, 08:16 AM   #10
corvette8n
corvette8n's Avatar
I turned on the captions so I could understand it, good job.
Old 03-20-2024, 08:59 AM   #11
Mart
Mart's Avatar
Sounded great, thanks Randall. Had no problems with voice or sound watching on my pc with stereo speakers.
Old 03-20-2024, 09:11 AM   #12
flatford8
flatford8's Avatar
Nice!!......thanks for posting......sounds great!!.......I understood every word....people say I talk funny too!!........Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 03-20-2024, 09:26 AM   #13
Seth Swoboda
Seth Swoboda's Avatar
I loved the dyno video. I too wish folks would post more of these. 129hp for a stock engine is pretty good. It should make for a nice cruising car. Good work.
Old 03-20-2024, 09:37 AM   #14
Zeke3
Zeke3's Avatar
Thanks for the video, I enjoyed the dyno pulls. It sounds like a real healthy engine.
Zeke3 is offline   Reply With Quote
Old 03-20-2024, 09:46 AM   #15
rockfla
rockfla's Avatar
Not sure WHAT torque number generally run but that is what caught my eye....201.# ft lbs of torque.....that is what you feel in the seat of your pants and under ones foot.
Old 03-20-2024, 10:17 AM   #16
sidevalve8ba
sidevalve8ba's Avatar
I imagine that moves that '46 coupe along quite well! Enjoyed the video Randall. Thanks for sharing.
The more I learn about new automobiles, the more I value my old ones.
sidevalve8ba is offline   Reply With Quote
Old 03-20-2024, 11:12 AM   #17
scicala
scicala's Avatar
And that's with a 3 bolt carb and intake manifold for a 239 Ford.
If you used a correct Mecury 4 bolt intake and higher flow Holley 885F or 1901 carb, you might have made 140 HP.
Sal
scicala is offline   Reply With Quote
Old 03-20-2024, 12:40 PM   #18
tubman
tubman's Avatar
It would be interesting to have a little more detailed information, such as the cam grind, overbore (if any), and if any work that was done on the heads.. The early 255's were rated at 110 HP, while the later ones were 125. If this engine is close to stock, those number seem to be right on. It's good to hear, as I was always disappointed with the numbers in JWL's book with a bone stock rebuilt 239.
I agree with Sal about the carburetor, except I'd use a 2G.
Old 03-20-2024, 01:52 PM   #19
Ol' Ron
Ol' Ron's Avatar
Yes, Born in Chicago, raised in winsconsim Worked in Ct for 30 years, and have lived in Vermont for the 40 years, you sound perfect to me America,. In JWL's book he used my dyno for the tests. The Dyno was a 300u0 GE electric unit, A UPS weight scale measured the torque output. Using the load cell brackets. The electronics of the unit was too expensive to repair UPS said the scale was a max of +-2%. Max HP from a 239 engine was 78 with out a generator or fan. This seemed kinda low but checking with others found that the Dyno was very accurate in it's load performance.. However after adding a Max# 1 can produced 112 hp.
In recent years I've been to many dyno runs, and know with alittle nudging ,here and there. you can get any amt of hP you want. Just ask any advertising agency
Gramps
Ol' Ron is online now   Reply With Quote
Old 03-20-2024, 08:47 PM   #20
Randall
Randall's Avatar
Glad you all enjoyed , that is the first flathead I have completely rebuilt,it has .080 pistons, stock heads, carb, intake stock size valves with 3 angle valve job and a Isky 817700 cam, springs ,adjustable lifters, I resized rods and replaced wrist pin bushings,
cam ,rod and main bearing, bought ol Rons book and asked Ronnie roadster some questions, thanks for the help!, its a little skidish seeing it come off motor stand and going wide open after warming it up on dyno thinking did I do everything right!
