01-01-2024, 12:30 PM | #21 |
Re: Ford Rear Brake Drum repair
I have a complete set of 1935 brake drum assemblies, front & rear for sale on another site. PM me for more details.
01-16-2024, 11:44 AM | #22 |
The Dorman 610-234 studs won't work, to small
The stud hole in the drum is 0.624 diameter. I'm trying to find the correct original wheel studs but not having much luck. I believe I'm looking for part number 48-1118 rear studs. |
01-16-2024, 02:42 PM | #23 |
To be clear, the original ones will need to be swedged. I would make sure you or your shop can do that. I believe you need a 20 ton press and the correct swedging dies
01-16-2024, 08:02 PM | #24 |
Correct about the swedging
But can’t find the correct studs that will need to be swedged |
01-16-2024, 08:08 PM | #25 |
You could try All Ford Parts in Campbell Ca. Jim in San Jose
03-06-2024, 03:37 PM | #26 |
