05-14-2012, 09:11 PM | #1 |
Model AR
Why is a early model A called an "AR"? I know what the differences are i just cant find out what the significance of the "R" is. Were these low production or fairly common? Thanks.
05-14-2012, 09:22 PM | #2 |
Re: Model AR
When a part was revised and no longer used in production the suffix was revised to the next letter and an “R” was added to indicate this part was no longer used in production but needed to be stocked to repair vehicles that had already been delivered. I don’t know if the “R” stood for repair or replacement but either makes sense (or maybe something else). The largest single group of changes occurred early with the replacement of the brake system. These early cars that utilized a large number of parts carrying the suffix “AR” were generally referred to as “AR” cars by the people in the hobby (but not by Ford). Although not as common, parts with the suffix “BR” exist as well as parts that were introduced later in production.
Charlie Stephens |
05-14-2012, 09:57 PM | #3 |
Re: Model AR
Charlie is correct and it was a mistake in the early 60's by Model A Restorers to use that term. We should not use it any more and refer to cars built in 1927 and about the first 6 months of 1928 as "early 28's". Of course now we have a new region and I believe it is called the "27ers". This is a fun way of referring to this group who either own or are interested in those extremely early cars.
Ken |
05-15-2012, 01:14 AM | #4 |
Registered User
Re: Model AR
this may have had a little to do with the nomenclature
05-15-2012, 10:42 AM | #5 |
Re: Model AR
Thanks, MOT! if Henry called them AR's, why can't we? (boy this is really stir things up..)
05-15-2012, 10:53 AM | #6 |
Re: Model AR
02-04-2016, 11:37 AM | #7 |
Re: Model AR
Found my old post from years ago, funny I know own one of these early 28 cars. However, mine is a mix mash of 28 and 30 parts , visually appearing as all 1928. The date on the gas tank is 6/ 1928. Does this make the cut off to be early?
Sent from my SM-G920T using Tapatalk |
02-04-2016, 11:43 AM | #8 |
Re: Model AR
The AR's also used different wheels and the parking brake handle was next to the cowl.
02-04-2016, 11:46 AM | #9 |
Re: Model AR
With a June 1928 I would think you have the separate parking brake and later style 21" wheels, and if so then this would be considered a later 28 Model A.
02-04-2016, 11:51 AM | #10 |
Re: Model AR
I have the brake handle on the left by the cowl and 21inch wheels. How do you ID the early wheels? Mine have the center cap that says made in USA.
Sent from my SM-G920T using Tapatalk Last edited by TradModelA; 02-04-2016 at 12:19 PM. |
02-04-2016, 12:36 PM | #11 |
Re: Model AR
It's the thickness of the hub in the center, the early wheel is about 1 1/8" the later is about 1 3/8", the larger Center allows clearance for the larger rear brake drum that encases the ebrake, the early 28's ebrake engages the cars 4 wheel brakes.
MrTexas was kind enough to send me info on the differences between the early and later cars, if you want a copy, just PM me and I'll send a copy your way Looking for the front bumper emblem that has "Ford, Made In Canada" |
02-04-2016, 01:23 PM | #12 |
Re: Model AR
Did You Know that some of the parts unique to the Convertible Sedan (400A not A-400) Had the AR suffixes. Does that make all 400As AR cars?
Bob |
02-04-2016, 02:11 PM | #13 | |
Re: Model AR
The "R" in this case most likely is used to designate Ford Factory "Replacement" parts.
02-05-2016, 02:39 AM | #14 | |
Re: Model AR
02-05-2016, 05:55 AM | #15 | |
Re: Model AR
Canadian production may have had a later changeover to the later features? |
02-05-2016, 08:18 AM | #16 | |
Re: Model AR
02-06-2016, 02:47 PM | #17 |
Re: Model AR
What is the definition for the AR 3.pdf
There is no such model as Model AR to begin with. Read the attachment for what an AR is. |
02-06-2016, 05:18 PM | #18 |
Re: Model AR
AR:
Always Rusting Always Rattling |
02-07-2016, 05:06 AM | #19 |
Re: Model AR
Until I started reading this web site a couple of years ago I had never heard the term early 28 which isn't a Ford term anymore than ar is or deciding to call them 400 a instead of a400. Who decided that this is wrong and to change the nomenclature? It seems to me someone has way too much time on their hands to change something that works just fine.
02-07-2016, 05:26 AM | #20 | |
Re: Model AR
