Old 02-10-2016, 06:06 PM   #1
dave11
Default shifter fork pins
While rebuilding my gear shifter assy, I noticed there is some play in the pin holes for the shifter fork to shaft.
Before I replace the pins and peen them in place, has anyone tried peening the pins when they are red hot?.....similar to installing a frame bracket rivet??
Dave
dave11 is offline   Reply With Quote
Old 02-10-2016, 06:16 PM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: shifter fork pins
The pins are hollow and have a seam, so I just insert an awl and spread the end just enough to keep the pins from falling out.
Old 02-11-2016, 10:36 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
There should be no (zero) play in the fit of the shift fork pins. I use blued-steel roll pins instead of the stock pins, and I spread the ends of the pins with a tapered drift pin.
Bob Bidonde
Old 02-11-2016, 10:50 AM   #4
dave11
FWIW....the hot forging of the pins did not seem to help much, not sure why as it is the only way to install frame component rivets.
I might try the spring pin method.
Dave
Old 02-11-2016, 11:08 AM   #5
2manycars
2manycars's Avatar
I used the spring pins on the last one I did.
2manycars is offline   Reply With Quote
Old 02-11-2016, 11:10 AM   #6
Mitch//pa
Roll pins will work
Old 02-11-2016, 08:10 PM   #7
Larry Jenkins
Originally Posted by Mitch//pa View Post
Roll pins will work
Roll Pins and Spring Pins.. Sam Ting?
Good enough.. Isn't.
Larry Jenkins is offline   Reply With Quote
Old 02-11-2016, 08:13 PM   #8
Mitch//pa
Yes. I always called them roll pins
Old 02-11-2016, 08:54 PM   #9
Larry Jenkins
I do too. Old age?
Larry
Old 02-11-2016, 09:26 PM   #10
2manycars
2manycars's Avatar
Actually roll pins are different, in that the spring material is actually rolled more than 180 degrees. They are still available. I grew up calling split pins roll pins, and that is what they are usually called. Mc Master Carr calls them coiled spring pins and slotted spring pins.
http://www.mcmaster.com/#standard-spring-pins/=11338p5
Old 02-11-2016, 09:31 PM   #11
31 RPU
I used roll pins and they work really well and take out the play.
31 RPU
31 RPU is offline   Reply With Quote
