02-09-2016, 10:20 PM | #1 |
Engine Support Device
Where is the best place on the block to mount the support for turning the engine while working on it ? There are 2 holes on the water flange which are in the center of the engine. There are 4 holes on the rear but 2 of those are on the thinner casting on the bottom of the block at the crank case lip.
02-09-2016, 10:27 PM | #2 |
Re: Engine Support Device
side. with proper bracket for mounting engine. See my avatar.Model A Vendors sell these.
www.whidbeymodelaclub.com |
02-09-2016, 11:22 PM | #3 | |
02-09-2016, 11:25 PM | #4 |
I agree on this type.
Fred Kroon 1929 Std Coupe 1929 Huckster |
02-09-2016, 11:51 PM | #5 |
I really like the crank turner....
02-10-2016, 08:03 AM | #6 |
02-10-2016, 06:10 PM | #7 |
This is a repeat of a post made in late 2015:
I have attached a few photos of the engine stand adapters I use. I greatly prefer for engine break-down and assembly to use the adapter that holds the engine from the rear. The rear mount adapter allows for much easier access to the internals of the engine for all portions of the assembly. Once assembled, I change the engine over to a side mount to allow the mounting and truing of the flywheel housing and flywheel. This change over only takes 3 minutes with a chain hoist. I also prefer a single wheel at the center of the engine stand. Some say it is a bit "tippy", I do not find it to be. I have two stands with a wider setting of two wheels under the center of the engine and I find my self constantly tripping over the extra width of these stands and they are the least used stands in my shop. Note that I have permanently welded the spacers and arms of the adapter to the main plate to provide a more ridged assembly and to have repeatability in the setup. I use the top two holes in the block that hold the two ears on the flywheel housing and the two lowest holes near the panrail. All of these holes require a 7/16" NC bolt. Your spacer length will dictate the length of bolt required. For safety, make sure you have about 1/2" engagement of bolt into the block. I build about 25 engines each year and break-down quite a few more. I am stating what works best for me. JMO. Good Day! www.durableperformance.net Click on the photos below to enlarge: . |
02-10-2016, 08:29 PM | #8 |
Dave, is that a KRW issue claw hammer you are using on that crank in pic #3 LOL
'31 180A |
02-10-2016, 10:47 PM | #9 |
Thanks for all the quick replies . Ordered side adapter.
02-11-2016, 08:59 AM | #10 | |
I would let one go but it would not be inexpensive! Good Day! Last edited by Dave in MN; 02-17-2016 at 09:08 AM. |
02-11-2016, 01:06 PM | #11 |
I use the claw hammer my wife found in the parking lot before we met.
