02-01-2020, 08:14 PM | #1 |
6 volt battery
Where can you buy a battery for your model a ?? I went to a couple of places and had no luck. Thank you in advance !
02-01-2020, 08:16 PM | #2 |
Re: 6 volt battery
A tractor shop should have one.
02-01-2020, 08:29 PM | #3 |
Re: 6 volt battery
02-01-2020, 08:30 PM | #4 |
Re: 6 volt battery
New Jersey
02-01-2020, 08:54 PM | #5 |
Re: 6 volt battery
Try NAPA, they have 4 listed or Interstate Battery Co. I buy my 6 volt batteries from Interstate, they have good quality and a large selection.
02-01-2020, 09:12 PM | #6 |
Re: 6 volt battery
I always put my battery's on a 1 amp maintainer in the winter.. always last 5 years or more. Rual King usually has the best price. |
02-01-2020, 09:34 PM | #7 |
Re: 6 volt battery
got mine at Rural King
02-01-2020, 09:54 PM | #8 |
Re: 6 volt battery
I got a 6volt optima battery from Pep Boys
02-02-2020, 01:20 AM | #9 |
Re: 6 volt battery
Online look up a Group 1 battery for 6 volts.
9 1/8 length, 7 1/8 width, 9 3/8 height 6v group 1 batteries are found by the following numbers; NAPA - BAT 7244 Exide - 7200 Tractor supply - Com 1 HP (part number 0470506) I think. Autozone - 1-6 volt Ultrapower #901MF from Deka interstate part # 1-VHD The internet search should provide you with parts stores that carry what you need.
02-02-2020, 01:22 AM | #10 |
Re: 6 volt battery
Batteries Plus Bulbs or Battery Solutions. or Amazon
02-02-2020, 09:31 AM | #11 |
Re: 6 volt battery
Optima is the best 6 volt battery I ever bought, compare prices online.
02-02-2020, 10:01 AM | #12 |
Re: 6 volt battery
I found one at a local CarQuest, but next time I'm just going to Rural King. They have the best pricing around here. Like JFranklin said, any tractor shop has them.
1928 Niagara Blue Phaeton 1972 Olds 442 Convertible 1979 MGB -Life's Too Short To Drive Boring Cars- |
02-02-2020, 10:19 AM | #13 |
Re: 6 volt battery
we dont have Rural King, but do have Tractor Supply- about 75. for a 6 volt battery.
as discussed before the Optimas can be great or not. used to buy them on amazon for around 125. |
02-02-2020, 11:30 AM | #14 |
Re: 6 volt battery
Being as the battery is out of sight , I chose to convert to 12 volt . No wires need to be changed as long as it remains positive ground . I replaced the coil with a 3 OHM flame thrower coil rather than having to use a resistor at the coil connection . This is a very simple conversion . I did have to replace all of the bulbs but that's no big deal .
02-02-2020, 12:27 PM | #15 |
Re: 6 volt battery
I bought a optima from speedway it came in the mail in 2 days, free shipping, last optima lasted me 16 years
02-02-2020, 12:58 PM | #16 |
Re: 6 volt battery
Interstate in both my A and Jeep. Subaru in my Subaru.
02-07-2020, 08:03 PM | #17 |
Re: 6 volt battery
Group 1 or an AGM from Interstate and a hold down kit from Snyders.
03-03-2020, 12:08 AM | #18 |
Re: 6 volt battery
I am thinking of an Optima battery for this sport coup I'm working on, someone installed juice brakes on it and put the master cylinder where the battery goes, but there is enough room to put one of these upside down in about the location where the orginal went, what have been your experences with these an d will they work fine on the generator and cut out.
Thanks |
03-03-2020, 12:32 AM | #19 |
Re: 6 volt battery
6V Yellow Top !
03-03-2020, 12:33 AM | #20 |
Re: 6 volt battery
I got 16 years out of last optima, using generator,and halogen headlights, never use maintainer, just drive at least every 6 months--- the charge rate has to be set for YOUR use, I drive a lot at night, for me 14 amps allows me to drive as much as I want at night,
