Old 04-22-2024, 05:05 PM   #21
Jim/GA
Jim/GA's Avatar
Default Re: Distributor Cap Advance Lever Slot
Originally Posted by Jim Mason View Post
Hard to read. No tolerance noted as it's not a critical measurement
Thank you, Jim Mason. And thank you, Terry. I knew you'd know.
Jim Cannon
Former MAFCA Technical Director
"Have a Model A day!"
Jim/GA is offline   Reply With Quote
Old 04-23-2024, 12:58 AM   #22
Bob Johnson
Bob Johnson's Avatar
Easier to read
Bob Johnson is offline   Reply With Quote
Old 04-23-2024, 08:00 AM   #23
sdp.fordbarn
Be sure to check the width of the advance arm on the upper distributor plate. I bought a new upper plate and found the advance arm was much wider than my original which reduces the available advance travel.
sdp.fordbarn is offline   Reply With Quote
Old 04-23-2024, 09:06 AM   #24
Jim/GA
Jim/GA's Avatar
Yes, that's a good point, and it will send me in search of an entirely different original Ford blueprint or two, for the breaker plate.
Jim Cannon
Old 04-23-2024, 12:55 PM   #25
Bob Johnson
Here you go Jim
Old 04-24-2024, 08:35 AM   #26
Rob Doe
I seem to remember reading that the Model A engine with a stock 4.2 head can only utilize 28-32 degrees of crankshaft advance. High compression heads use even less. 20 degrees of distributor advance will be ~40 degrees of crankshaft advance. If the spark advance lever on the upper plate is just touching the distributor body at full retard, then no more than 7 to 8 notches are required, and wouldn't that be at high speeds of 50 plus or there about????
I've wondered about this. If you're using a 2 tooth Gemmer, a small window can possibly work fine if you're never driving at max speeds.
"It ain't what you know for certain that gets ya in trouble. It's what ya know for certain that just ain't so!"
Rob Doe is offline   Reply With Quote
Old 04-24-2024, 09:04 AM   #27
the cooch
the cooch's Avatar
Get the column clamp at the box really tight! There is a possibility of the crank handle kicking back while hand starting if the column rotates on the housing and goes unnoticed! The spark lever, even all the way up will still have the timing advanced if the timing is set correctly and the column rotates a little c.c.w. Ask me how I know….Chris, in Boulder
the cooch is offline   Reply With Quote
Old 04-24-2024, 06:04 PM   #28
Jim/GA
Jim/GA's Avatar
Originally Posted by Bob Johnson View Post
Here you go Jim
Thanks!!!
Jim Cannon
Old 04-24-2024, 06:08 PM   #29
700rpm
700rpm's Avatar
I have four, two in cars and two in extra stock. All four have 1” slots. One has Ford script on it, likely a repro. I’ve had these for years and don’t remember where I found ‘em. The two on the cars seem to function as they should.
Ray Horton, Portland, OR
Old 04-24-2024, 07:07 PM   #30
Jim/GA
Jim/GA's Avatar
Here you go Jim
It's good to see the part number, but there are no dimensions on this drawing...
Jim Cannon
