Old 08-09-2023, 04:20 PM   #1
flathead34
flathead34's Avatar
Default Brake Lights Dilemma
On our '34, when we have the brake lights on and then when the headlights are turned on the brake light goes off. This only happens on one brake light, the other performs normally. In studying this problem, we observed that only one filament was being used by both. We changed out numerous double-filament bulbs and they all performed the same, the brake light and the head light used that same filament on that side. What do we have to do to correct that and not have that brake go off when the headlights are on?
flathead34 is offline   Reply With Quote
Old 08-09-2023, 05:51 PM   #2
Bob C
Default Re: Brake Lights Dilemma
Are you sure it's the brake light and not the tail light that's going out?
If it's the tail light it could be a grounding problem. Only one head light filament
should be on at a time. One filament is low beam and the other is high beam.
Old 08-09-2023, 06:58 PM   #3
paul2748
paul2748's Avatar
It sounds like a grounding problem. Run temporary grounds to each taillight housing and see if that solves the problem
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-09-2023, 08:48 PM   #4
JayChicago
JayChicago's Avatar
Really confusing when you say headlights when you are talking about the taillight. Yes headlights and taillights come on together, but the headlights have nothing to do with this problem.
As said above, this is a classic symptom of no ground at the bad light's socket. Brake light is using the taillight filament and wiring to find ground at the other side's good socket. Only the taillight filament lights up because it is smaller. And then this strange path to ground gets blocked when taillights have power on.
To fix this, look at how the socket is attached. Needs clean, tight, metal-to-metal contact between the socket and truck body. Sometimes it's a coat of paint breaking the contact.
Old 08-10-2023, 05:32 AM   #5
big job
big job's Avatar
Your best friend is a simple test light
big job is offline   Reply With Quote
Old 08-10-2023, 06:16 AM   #6
Terry,OH
Terry,OH's Avatar
Sounds like the problem is the connections or grounds to the one light that goes off. What light bulb are you using? the brake light is just one filament of the dual filament light bulb with the tail light being the second.
Old 08-10-2023, 09:45 AM   #7
flathead34
flathead34's Avatar
Thank you guys for your responses We will look at the grounding. There is some confusion the way I described the problem when we turned the headlights on. We step on the brake pedal and the brake lights come on. With brake lights on we turn on the headlights. One brake light turn off. Do you think this happens because improper grounding on that one tail light? The other brake light works properly with the headlights on.
Old 08-10-2023, 10:25 AM   #8
Bob C
The most likely cause is a bad ground.
Old 08-10-2023, 10:45 AM   #9
JayChicago
JayChicago's Avatar
Yes. That is what everyone here is saying.
Old 08-10-2023, 01:01 PM   #10
flathead34
flathead34's Avatar
Thanks for all you help. Off to find the ground problem
