Old 09-05-2010, 11:51 AM   #21
kelley's restoration
kelley's restoration's Avatar
Default Re: How To Lower The Model A The Old Fashion Way
Originally Posted by roccaas View Post
Big shoes on that horse!
525 16 front 25.2 dia800-18 rear 34 diatk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information
[email protected]
kelley's restoration is offline   Reply With Quote
Old 09-05-2010, 12:12 PM   #22
LeroyM
LeroyM's Avatar
Originally Posted by kelley's restoration View Post
i guess my only concern now is the shock arm hitting the fender when the suspension goes through its traveltk
I went out and took some measurements. With the shocks in the natural resting position they are about 5/8" to 3/4" away from the fenders. It looks to me like the shock arms would be going down when in motion and if that is the case there is plenty of room since they get further away from the fenders as they go down.
LeroyM is offline   Reply With Quote
Old 09-05-2010, 01:45 PM   #23
Rowdy
Thanks for sharing. I will pass along the info to a freind who is not yeat a part of Fordbarn past or preasant dispite having a computer and an A. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 09-05-2010, 07:54 PM   #24
i am not trying to be a jerk here so please don't take any offence to my questioning but if you hit a bump and the spring compresses i think it will hit the fenders. i went out today and put my shocks on and i am a little concerned about putting dents in them if i hit a rail road crossing or a bumpy intersection. i guess a bit of driving time will tell for us bothtk
[email protected]
Old 09-05-2010, 08:22 PM   #25
Thom IV
Thom IV's Avatar
WoW. Your car sure looks neat. I've got 16 inch wheels on mine, Lowering it would sure improve the appearance. You've just about got me convinced. you did a great job.
Thom IV is offline   Reply With Quote
Old 09-05-2010, 08:31 PM   #26
LeroyM
LeroyM's Avatar
Can anyone with a stock Model A measure and post how much distance you have between the shock arm and the fender in the resting position?
Once I get my tie rod back on I'll take some speed bumps and ruff roads to see if there is any rub on the fenders with the shocks and post my results.
Old 09-05-2010, 09:51 PM   #27
jerseyboy
jerseyboy's Avatar
Leroy,
Is this what your looking for?
She just don't have the appetite
For gas somehow,
And Dad, I got four carburetors
Hooked up on it now.
I tried to hook another
To see if I'd do a little good,
But ain't no place to put it
'Less I perforate the hood.
Wanted, lower side sections of 32 radiator cowl.
jerseyboy is offline   Reply With Quote
Old 09-06-2010, 03:51 PM   #28
Mike/Nebraska
I wanted to do the same thing with my roadster. What I finally did was I got in touch with the guys from Eaton Spring Co. and told them what I wanted to do and asked if they could help. What they came up with was a new spring with three less leaves, the same tension of the stock Model A spring, and a three inch drop. It fit great and the car sits "right", I'm really pleased. It may not be the way they had to do it in the old days, but it worked for me.
Mike/Nebraska is offline   Reply With Quote
Old 09-06-2010, 06:41 PM   #29
LeroyM
LeroyM's Avatar
Post a picture Mike if you can, lets see how it looks. The new 10 pack springs are very stiff and I think the Model A's are over sprung anyway for modern roads. Taking 3 leaves out of mine really made a difference in the ride quality.
Old 09-06-2010, 06:43 PM   #30
msmaron
msmaron's Avatar
Send a message via AIM to msmaron
May i ask WHY would you do that to a Model A???? Doesn't seem like a Model A then??
Mark Maron
Ill., Region MARC & MAFCA
MARC JSC Member MAFFI Trustee
National Facebook Admin.
https://www.facebook.com/groups/MARC.group/
A7191-Sport Coupe
29 Roadster
29-Town Sedan
29-Original Special Coupe
msmaron is offline   Reply With Quote
Old 09-06-2010, 07:47 PM   #31
LeroyM
LeroyM's Avatar
Well to me the Model A is the body style and look. It was very common back in the early 40's to replace the wheels and tires to 16's because of WWII and other size tires being harder to get or come by. I'm sure more then a few Model A's were lowered back then to keep things looking right.
Also being a younger guy, I'm 33 by the way. I'm more into driving the car anywhere and having it ride and look good at the same time more so then trying to match each and everything on the car when it left the factory.
Everything I have done to the car is easy to undo since it's all bolt on. All of the parts I took off will be sitting in the garage. Different strokes for different folks as they say.
Old 09-06-2010, 07:58 PM   #32
msmaron, i too am a younger guy(31) and everything i have done can be easily switched to stock by removing a few cotter pins and bolts. This is just an expression of what i want done to my car, not what i do to all the cars we work on.i'll show it to you at park on park in mundelion this week.tk
[email protected]
Old 09-06-2010, 11:17 PM   #33
hotrodA
hotrodA's Avatar
That's perfect! Just what I'm needing to do to my 31 pickup. Thanks for the info.
hotrodA is offline   Reply With Quote
Old 09-07-2010, 08:23 AM   #34
Equipped28
Equipped28's Avatar
Send a message via MSN to Equipped28
what is it with young guys and 32 axles on model A's im 17 my roadster in the works
Equipped28 is offline   Reply With Quote
Old 09-12-2010, 10:00 PM   #35
Lowbuckboz
Lowbuckboz's Avatar
Your cars look good lowered. I did the same thing, can be converted back to stock very easily. I have been suprised by the purists reactions to it, they all have liked it. Here is mine....
Lowbuckboz is offline   Reply With Quote
Old 09-12-2010, 10:27 PM   #36
youngrodder1929
youngrodder1929's Avatar
19 here yep its got a 32 axle
youngrodder1929 is offline   Reply With Quote
Old 09-13-2010, 06:56 AM   #37
LeroyM
LeroyM's Avatar
One update.
I got the tie rod ball studs in the mail from Mac's last week and went to put them on over the weekend. Well for the life of me I couldn't get the nut to go up far enough to allow the carter pin to go in. I got a longer pull bar but still no luck. My next step was a piece of pipe over the pull bar. After tightening and tightening I broke the tie rod ball stud off and was still to far away to get to carter pin to go in.
Luckily my dad had a fork to knock out the tie rod ball stud without any damage done to the spindle. What I ended up doing with the other side was to notch the castle nut with a hacksaw blade and only use half a carter pin.
I called Mac's back and ordered another tie rod ball stud and asked were the tie rod ball studs and nuts made in the USA and they said they were. Lesson learned, don't use long pieces of pipe on a pull bar to try and tighten nuts to allow a carter pin to go in and also new things break to.
Old 09-13-2010, 08:00 AM   #38
mine have a special real short nut
i lost one of them and had to machine the back off of another castle nut to match the others
tk
[email protected]
Old 08-23-2012, 02:54 PM   #39
bgarrett
bgarrett's Avatar
It is documented that Edsel Ford tried to get his father to design the A to sit lower
bgarrett is offline   Reply With Quote
Old 08-23-2012, 09:41 PM   #40
Bassman/NZ
Bassman/NZ's Avatar
Smart boy that Edsel. Henry should've listened to him.
Bassman/NZ is offline   Reply With Quote
