Old 03-24-2022, 05:16 AM   #1
panhead_pete
panhead_pete's Avatar
Default Brake light switch
Hi from Japan
Im getting my 30 coupe ready for registration and need to replace the brake light switch. Is there a reputable supplier as I prefer OEM if possible.
Thanks
Pete
File Type: jpg 275986232_1004857590236368_5927012578345195410_n.jpg (65.3 KB, 111 views)
Looking for an unrestored 33 34 3W or 5W coupe.
Thanks
panhead_pete is offline   Reply With Quote
Old 03-24-2022, 07:35 AM   #2
ndnchf
ndnchf's Avatar
Default Re: Brake light switch
There seems to be two switches available. A cheapo one that runs $10-$15. and a high quality one like this that runs $50-$60.
https://www.brattons.com/BEST-QUALIT...uctinfo/19411/
I looked at both and was going to buy the high quality switch, but refurbed my original instead.
ndnchf is offline   Reply With Quote
Old 03-24-2022, 08:54 AM   #3
Patrick L.
Patrick L.'s Avatar
The originals are best and can be redone.
The cheap chinezium ones are junk.
The expensive repro's are good, but, seem to be out of stock at some vendors.
Old 03-25-2022, 03:50 PM   #4
GRutter
GRutter's Avatar
Look for the switch with brass bushings around the shaft
GRutter is offline   Reply With Quote
Old 03-26-2022, 06:58 AM   #5
Patrick L.
Patrick L.'s Avatar
Yep.
Old 03-26-2022, 10:39 PM   #6
panhead_pete
Thanks fellas will be ordering one from Brattons.
Thanks
Old 03-27-2022, 01:50 PM   #7
BillCNC
BillCNC's Avatar
It's so easy to add brass bushings to the existing inexpensive 30-31 switches, and in doing so, you'll save yourself $45.00. All that's needed is a small piece of K&S 3/16" (.187") brass tubing.
Regards
Bill
BillCNC is offline   Reply With Quote
Old 03-27-2022, 07:47 PM   #8
GRutter
GRutter's Avatar
Regards
Bill
I disagree. If you have ever seen an original, or the ones made by A&L and sold by some of our vendors, the brass bushing is a machined part that fits into the case halves, not a piece of tubing.
Old 03-27-2022, 09:13 PM   #9
BillCNC
BillCNC's Avatar
I did a very detailed writeup (11-29-2019) about the mod, and it's posted on the other forum. It's a simple and rock solid mod thats cheap and still is functioning perfectly today. The tubing was just quick description I used, but a well fitting pieces of brass is just that regardless if was installed during manufacturing or after. I only offered it as an option for those that like to improve what they currently have.
Regards
Bill
Old 03-28-2022, 10:43 AM   #10
katy
katy's Avatar
Can you provide a link? I tried a search and no joy.
Old 03-28-2022, 11:50 AM   #11
BillCNC
BillCNC's Avatar
Site wont let the link work. Try the advance search or go into the electrical tech section.
Advance search > Key word = switch > member = Bill CNC
Regards
Bill
Old 03-28-2022, 12:26 PM   #12
Afordman31
Afordman31's Avatar
Regards
Bill
Just looked at your post to fix brake light switch with brass tubing. Very nicely done A+.
Afordman31 is offline   Reply With Quote
Old 03-29-2022, 10:58 AM   #13
katy
katy's Avatar
Thanks for the link, got it in a notification email from administration. Looks good, problem is that for some unbeknownst reason I can't sign in to that forum and get the pictures. Methinks I can figure it out from the explanation.
Old 03-29-2022, 01:04 PM   #14
BillCNC
BillCNC's Avatar
Yeah, I probably should make one into a PDF file so it can be downloaded or published. I would have posted it here as well, but there isn't any sub-forums to post it in on this site.
Regards
Bill
Old 03-30-2022, 01:54 PM   #15
Ed in Maine
The good quality switch was made by A&L Parts. They have relocated and I don't know what their status is now. Maybe someone can comment about them. I have to mention that Al Lepore was a great friend of mine and made many contributions to the hobby. I have one of his reproduction 1932 horns on my 1932 Coupe and I run my fingers over the bell of that horn and think of him often. Ed
Ed in Maine is offline   Reply With Quote
Old 03-30-2022, 05:09 PM   #16
GRutter
GRutter's Avatar
A&L now only sells to the vendors - no more direct to the public sales. They still make excellent products. The vendors sell the switch make by A&L
Old 03-30-2022, 06:47 PM   #17
panhead_pete
Thanks all, ordered the USA made one via Brattons.
Thanks
