Old 12-17-2014, 04:30 PM   #1
Brian T
Brian T's Avatar
Default Painting Tillotsons
I know some of you will question why, but I will ask anyway, I would like to paint my Tillotson carbs black, I am thinking I will use Rustoleum appliance paint which I believe is an epoxy type paint?.
As they have a smooth surface I need to key the surface for the paint to adhere, they are to complex of a shape to sand on and I did not what to fine media blast them, is there an acid such as Ospho that would etch them enough for this purpose.
I have read that there is no absolute fuel proof paint, the good model airplane paint that did work is outlawed in Cali and maybe else were, also I understand that curing enamel paint is a must and can take a few weeks (not a problem in this case) --- any suggestions appreciated.
Thanks Brian.
Nothing can be made foolproof, ---- fools are ingenious bastards.
Brian T is offline   Reply With Quote
Old 12-17-2014, 04:45 PM   #2
Fullraceflathead
Fullraceflathead's Avatar
Default Re: Painting Tillotsons
If you want to spend a little more money than painting I'd look into having the Tillotson pieces anodized.
Powder coating is tuff but you would have to have the vendor Not paint any interior surfaces, threaded holes etc.
Fullraceflathead is offline   Reply With Quote
Old 12-17-2014, 07:12 PM   #3
Gary Gregory
Gary Gregory's Avatar
Dont waste your money...the paint wont stay if the carb leaks...and all my Tillotons weep a little at the bowl gasket or at the drain plug...the paint will peal there first.
Gary Gregory is offline   Reply With Quote
Old 12-17-2014, 08:52 PM   #4
bikejunk
most paint their carbs with aero gloss dope u can buy at hobby shop its fuel prof. don't think iv ever seen a tillotson painted .
bikejunk is offline   Reply With Quote
Old 12-17-2014, 09:21 PM   #5
Joe K
Joe K's Avatar
Lacquer works well. Keep it thin.
MOre detail on this at http://www.rcuniverse.com/forum/rc-f...oof-print.html
Joe K
Shudda kept the horse.
Old 12-17-2014, 09:31 PM   #6
Mitch//pa
here is what snyders reccomends for carbs
Old 12-17-2014, 09:53 PM   #7
Purdy Swoft
Purdy Swoft's Avatar
I wouldn't paint a pot metal carb. I have painted Zenith carbs with lacquer and had good results.. NAPA use to sell a product named triple etch that will etch alloys, I'm pretty sure that they still do Rustoleum will probably wash right off with alky-rub gas . Why not try the Snyder lacquer paint that Mitch shows. I have purchaced black lacquer in spray cans at Advance Auto Parts, Auto Zone and sometimes Walmart . Its your project and your choice .
Old 12-17-2014, 10:33 PM   #8
w.michael
w.michael's Avatar
I've painted my tillotson many times. Many times. Many times. About once a week for one whole summer. Then I gave up on keeping the thing painted. Every paint I tried wrinkled and peeled off immediately.
W. Michael
w.michael is offline   Reply With Quote
Old 12-17-2014, 11:34 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
About 20 years ago I painted a small engine gas tank and let it set and dry for a year. As soon as the corn crap gas hit it the paint lifted and wrinkled. I never had that problem with good gas from the old days.
BTW, it was on the news tonight that the University of Minnesota research department has finally declared corn crap gas is actually worse than real gas. They said the emissions are the same and when you factor in all the energy wasted to produce, refine, and transport the crap, it much worse than just using good gas.
Naturally the ethanol producers disagreed.
Old 12-17-2014, 11:41 PM   #10
Purdy Swoft
Its the alky- rub that causes the problem. Its suppose to help the farmers but it sure doesn't help the old car hobby. anybody that says that it has no effect just doesn't know what they are talking about .
Old 12-18-2014, 12:36 AM   #11
dlshady
dlshady's Avatar
I wonder how many millions of dollars they spent on that study in order to come to the conclusion that we all reached many years ago...
My latest build thread:
https://fordbarn.com/forum/showthread.php?t=67881
dlshady is offline   Reply With Quote
Old 12-18-2014, 11:19 AM   #12
jhowes
I have been runing two tilly's on a duel intake manifold for some time now that I painted blue with rattle can lacquer l They have held up well and do not leak. So it can be done, and they look good.
jhowes is offline   Reply With Quote
Old 12-18-2014, 01:45 PM   #13
Purdy Swoft
Real gas isn't that bad about removing acrylic lacquer. Good tillotson carbs don't leak as badly as Zenith carbs unless the bowl is warped . I bet the dual up draft Tillotsons look cool. I'm running dual B carbs on a couple of mine . I painted mine with spray can lacquer and no problems with the paint .
Old 12-18-2014, 02:00 PM   #14
jkeesey
jkeesey's Avatar
I always paint mine with good old gloss black lacquer. I prefer the look of a Tilly painted over the pot metal finish. I usually rub the bodies with scotch brite just to give the paint something better to bite to, then wash them in lacquer thinner and blow dry before painting.
jkeesey is offline   Reply With Quote
