04-14-2024, 04:08 PM | #1 |
Power brake booster grommet - 1968 Merc.
Need to replace the grommet and might as well change the booster check valve on my 1968 Cyclone GT. Cannot find a listing or confirm a Dorman number anywhere with specs. The hole on the booster is 1 inch, and the check valve is .85 of an inch.
If I can get a Dorman part number or another brand, I could likely buy locally. The check valve still works so I'm more worried about the grommet at the moment. I found a Dorman part number: 80191 but there are no specs on size at all even on the Dorman website. Cannot confirm if this will fit. |
04-14-2024, 05:24 PM | #2 |
Re: Power brake booster grommet - 1968 Merc.
- https://www.npdlink.com/product/powe...k-valve/205445
***** "My 57 A/T Only Has Two Speeds" I had the same problem with a Powerglide ... no matter how hard I tried, I could NOT get that thing to shift into 3rd. - FACETIOUS - FUNK & WAGNALLS - 1: joking or jesting often inappropriately : waggish just being facetious 2: meant to be humorous or funny : not serious a facetious remark |
