Old 09-10-2020, 11:29 PM   #1
duke36
Default '31 slant window loose door shafts
Am looking for suggestions to tighten up the inside door shafts that many experience becoming loose from using the handle as a door pull. The vendors sell the complete latch jamb and triangular mechanism but no apparent repair parts for the shafts. Our handles fit fine on the shafts that are loose.
Old 09-11-2020, 07:35 AM   #2
Oldbluoval
Oldbluoval's Avatar
Default Re: '31 slant window loose door shafts
Are you sure the remote is not bad or the spring inside it is not broken? The remote spring is available but assembly has to come out of car.
If it is just the square and the shaft having too much play you could just skim it a bit. But you says that’s not the case
I can’t think of another quick fix with the remote in the car; removal is painful.
If it were out of the car you could put a spot with a mig welder and grind till tight fit
I’ve rebuild those latches for years and suspect there’s more going on as noted above in this writing
Old 09-11-2020, 09:15 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
I had this condition on my Coupe. To remove the play, I made a brass bushing out of tubing. Split the bushing if necessary. You can slide a bushing onto the shaft and into the sheet metal supporting the shaft. Secure the bushing in place with a thread locking compound or epoxy adhesive.
Bob Bidonde
Old 09-11-2020, 10:21 AM   #4
duke36
Thanks Bob, good idea. I have some thin wall brass tubing from ACE hardware that probably would work. All the lock springs work great with sharp clicks, just the front doors have the most wear where the shaft enters the triangular support plate..
Old 09-11-2020, 01:41 PM   #5
Oldbluoval
Oldbluoval's Avatar
Coupe and slant completely different set up
If the male and female square fit (which you said above they did) the remote assembly is the problem. Does the handle hold in the lock position?
Old 09-11-2020, 02:07 PM   #6
duke36
This is where the issue is. The handle holds well in lock pos. The shaft or bushing appears worn in the tri. plate
Old 09-11-2020, 03:23 PM   #7
Oldbluoval
Oldbluoval's Avatar
Surprisingly I haven’t seen much of that. I’ve probably rebuilt a 100 of them. Usually the spring is broken or just missing (fell out after breaking)
Likely the only good answer is removal. And a major pain as the door panel has to come off and the latch come out. Can get by without removing window reg usually!!!
I likely have one if you want to go to the pain to remove.
I have lots of latch parts too.
Old 09-11-2020, 03:38 PM   #8
duke36
Old blu, sent you a pm.
