07-12-2022, 08:51 AM | #1 |
1940 gear oils
I am planning on changing my transmision and rear end fluids in my stock 1940 Ford Standard Coupe.
What is everybody using to make the 82 year old components happy? Brands and weights? Thanks Tom. |
07-12-2022, 09:20 AM | #2 |
Re: 1940 gear oils
I use 85-90 wt and you really need GL4 if you can find it. It’s not hard on the brass parts in the transmission.
07-12-2022, 09:33 AM | #3 |
Re: 1940 gear oils
I use 90w and a max of GL4 - stay away from GL5 in the transmission, ruins brass synchros.
07-12-2022, 11:55 AM | #4 |
Re: 1940 gear oils
I use this in my 1940 Ford transmission and rear end.
https://www.oreillyauto.com/detail/c...ar+lube&pos=11 For winter driving you may want to use a lighter weight GL4. https://www.oreillyauto.com/detail/c...ar+lube&pos=13 I have found Oreilly sells this product at the lowest price. |
07-12-2022, 02:56 PM | #5 |
Re: 1940 gear oils
For years now I have used Sta-Lube GL4 / 140wt. in trans & rearend. I get it@ NAPA.- F F
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
07-12-2022, 07:36 PM | #6 |
Re: 1940 gear oils
07-12-2022, 09:00 PM | #7 |
Re: 1940 gear oils
Gear oils labeled both GL4/GL5 should also be safe.
Mike Jr. here. I get on here every few months to check messages, and look through his almost 500 saved messages for information on the '29 and '34 I still have. A lot of very nice people on here. He truly enjoyed Ford Barn. |
07-13-2022, 10:04 AM | #8 |
Re: 1940 gear oils
Thank You everyone for your wealth of advice!
07-13-2022, 10:32 AM | #9 |
Re: 1940 gear oils
GL-5 is high EP and the extra pressure additive can be harmful to the soft metal bushings and thrust washers in a transmission. It works fine in the rear axle though unless you have a model T.
07-13-2022, 12:56 PM | #10 |
Re: 1940 gear oils
One more thing to add... For those wanting a high performance GL4 oil, Brad Penn/Penngrade sells a nice formulation... for a reasonable price. Below are links to places that it.
One specializes in Ford Toploader transmissions, but it can be purchased at other places as well. Summit is the cheapest at $8/qt. Can read reviews at Summit. http://4speedtoploaders.com/store/gearoil.html https://www.summitracing.com/search/...n%20gear%20oil
07-13-2022, 08:00 PM | #11 |
Re: 1940 gear oils
07-14-2022, 07:14 AM | #12 |
Re: 1940 gear oils
Columbia has brass washers at the spider gears and both thrust faces of the axles. IMO stay away from the GL-5 in the Columbia.
