02-28-2014, 09:17 PM | #1 |
Vacuum leak
I replaced the cracked exhaust manifold on my completely stock A. I got the new one from Synder's. When putting it back together there was about a .010-.015 discrepancy between the level of
the new exhaust and old intake manifolds. (Exhaust higher than intake) I thought that the gap was small enough that the thick gasket with a compressible center would cover it. I guess I was wrong because I get a loud whistling sound that I never had before. The sound goes away at speed when driving. The car idles and runs good however. I am guessing it is a small but noisy vacuum leak. The intake manifold or carburetor don't seem to have a vacuum tap anywhere so I can't check with a vacuum gauge. I guess I will try putting heavier grease around the intake connections before I take it all off and go to a machine shop to level everything out. Anyone know what else whistles on an A engine? Thanks..... |
02-28-2014, 09:22 PM | #2 |
Re: Vacuum leak
You need to have the manifolds milled when they are bolted together.
Bob |
02-28-2014, 11:44 PM | #3 |
Re: Vacuum leak
You could "sniff" for the leak by using an unlit propane torch.
02-28-2014, 11:47 PM | #4 |
Re: Vacuum leak
80 year old original part and new reproduction part, Yea milling is manifold replacement 101.
03-01-2014, 08:24 AM | #5 |
Re: Vacuum leak
I would have changed them both out and never had to mill a new set yet..
03-01-2014, 08:30 AM | #6 |
Re: Vacuum leak
