Old 12-30-2023, 11:34 AM   #1
Bob Bidonde
Bob Bidonde's Avatar
Default A&L Horns
I have three reproduction horns that I bought from Al Lepore (A&L). With the covers off, how can I visually determine which horn is 12V and which is 6V?
Bob Bidonde
Old 12-30-2023, 11:44 AM   #2
Tom Endy
Tom Endy's Avatar
Default Re: A&L Horns
There is no visual way. Hook them to 6-volts and see if they ahooguh, if they don't, hook them to 12-volts and see if they ahooguh.
Tom Endy
Tom Endy is offline   Reply With Quote
Old 12-30-2023, 11:55 AM   #3
Joe K
Joe K's Avatar
I've used this method with the Hutchins horns. 12V horn on 6v sounds like a sick cow.
Start with 6v.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 12-30-2023, 02:28 PM   #4
nkaminar
nkaminar's Avatar
If you have two horns and one is 6 volt and the other is 12 volt you can compare the windings. The 12 volt will have more windings of a smaller gauge than the 6 volt horn. The wire for the 6 volt horn is usually 20 gauge and for the 12 volt horn it is 24 gauge (smaller). The turns for the 6 volt horn are around 40 whereas for the 12 volt horn it is about 100 turns. You could measure the wire diameter. It would be impossible to measure the turns without taking the horn apart but you could estimate them.
See https://www.youtube.com/watch?v=80HheWrv2_s
Old 12-30-2023, 07:13 PM   #5
updraught
updraught's Avatar
A 6 volt one on twelve volts sounds like the recent film Cocaine Bear
https://www.youtube.com/watch?v=gE1wZkMxGGE
updraught is offline   Reply With Quote
Old 12-30-2023, 07:34 PM   #6
Marshall V. Daut
Original 6-volt horn on the left, rewound 12-volt horn on the right. Note the difference in wire thickness, as "nkaminar" points out.
Marshall
Old 01-11-2024, 11:03 AM   #7
Mike V. Florida
Mike V. Florida's Avatar
Are you able to post a picture of the motors of the A&L horn?
Old 01-11-2024, 11:06 AM   #8
Ruth
Probably not since he was BANNED.
Ruth
Old 01-11-2024, 11:16 AM   #9
Big hammer
Bob Bidonde banned ? What happened ? He was one of the main contributors !!!
get a bigger hammer tap done
Old 01-11-2024, 11:40 AM   #10
DJ S
DJ S's Avatar
Wow. This is a shock to me as well.
DJ S is offline   Reply With Quote
Old 01-11-2024, 12:50 PM   #11
Bob C
Now it doesn't show him banned.
Old 01-11-2024, 02:24 PM   #12
Mike V. Florida
He is not banned. If he was it would say so under his name.
Old 01-11-2024, 02:31 PM   #13
Keith True
Keith True's Avatar
It did say banned,clearly,right under his name a couple of hours ago.I looked at his past posts,saw nothing to be banned for,and on every one of those he was marked banned too.I kind of figured it was a mistake and now it looks like it has been corrected.
Keith True is offline   Reply With Quote
Old 01-11-2024, 02:51 PM   #14
Bruce of MN
Bruce of MN's Avatar
Maybe they anticipated Bob getting crabby?
Bruce of MN is online now   Reply With Quote
Old 01-11-2024, 05:40 PM   #15
Ruth
Originally Posted by Keith True View Post
It did say banned, clearly, right under his name a couple of hours ago. I looked at his past posts, saw nothing to be banned for, and on every one of those he was marked banned too. I kind of figured it was a mistake and now it looks like it has been corrected.
He was BANNED and the thread was removed, that is why you can't find it. Maybe it was a warning BAN? I don't know, but as long as Bob has been on Ford Barn he should know that Ryan will not tolerate political posts.
Ruth
Old 01-11-2024, 05:40 PM   #16
alexiskai
alexiskai's Avatar
There was that inflation thread a couple days ago that the admin deleted, I assumed it was connected to that.
Old 01-12-2024, 07:33 AM   #17
jack wingard
IMO cars and politics don't go together. We take turns hosting our monthly club meetings
One member when hosting always feel the need to educate the attending members of his political beliefs. I no longer attend hen that person hosts.
jack wingard is offline   Reply With Quote
Old 01-12-2024, 07:59 AM   #18
don3527
Here's a link to our website showing the difference between the 2 different A&L new horns:
https://www.snydersantiqueauto.com/c...ce_diagram.pdf
don3527 is offline   Reply With Quote
Old 01-12-2024, 08:13 AM   #19
Chris in WNC
Chris in WNC's Avatar
Yes!
Brown's rule of political discourse #1:
No amount of bloviating by anyone (including me) will change another person's mind.
Epiphany must come from within.......
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 01-12-2024, 08:16 AM   #20
Bob Bidonde
Don3527, Thanks for posting the link to the A&L horns. That is exactly what I was looking for.
Bob Bidonde
