Old 02-21-2014, 08:23 PM   #1
ctfortner
ctfortner's Avatar
Default Trunk alignment - pic heavy
Got this on the HAMB group also, but figured not all yall in that group.
It may be an alignment issue, but I cant find it. When the trunk is closed its not flush. It is up around the rear windshield, but starting about half way back its raised up. Pictures can explain better than I can.
I have loosened the bolts holding the lid to the hinge, its as good as it will get. I have removed the locking mechanism pieces and re-installed, there is no adjustment left in them to allow it to fit better. Wonder if the thing is warped, or am I just missing something here. I can live with it for now, but if its something I overlooked I will correct it. There is enough gap in the curve of the trunk that the seal doesnt seal well enough to keep water out, so its a good size gap in places. The pictures are showing the trunk complete closed and latched, as good as I can get it in its current state.
This is pretty flush here
ctfortner is offline   Reply With Quote
Old 02-22-2014, 12:14 AM   #2
Alaska Jim
Alaska Jim's Avatar
Default Re: Trunk alignment - pic heavy
have the quarter panels been replaced? if so, may not have been installed correctly.
Alaska Jim is offline   Reply With Quote
Old 02-22-2014, 09:28 AM   #3
Ole Don
Ole Don's Avatar
Try moving the lid further ahead, even if you have to slot holes or make new holes. It looks like with a smaller gap in front at the top, the others may come closer to good. I commented once before here that my trunk lid doesn't appear to belong to the car its on.
Ole Don is offline   Reply With Quote
Old 02-22-2014, 10:29 AM   #4
Y-Blockhead
Y-Blockhead's Avatar
It has always amused me while looking through my 1955 Ford Shop Manual seeing Body Alignment pictures of a guy with a board 'tweeking' a fender or something.
Anyway there is a section on "Major Alignment" of the Luggage Compartment Door where you may (or not) get some tips. They actually suggest bending it by placing a rubber mallet in various places.
Don't know if that will help you but worth a look see...
Old 02-22-2014, 11:57 AM   #5
ctfortner
ctfortner's Avatar
THe thought did cross my mind to slot the holes a little bigger to move it forward a little. The qrts have not been replaced that I know of. My parents owned the car since the 70's and it hasnt been replaced since they owned it. I have the manual and was laughing at the major adjustment last night. I might do that without a paintjob on it, but wont be trying it now
Old 02-22-2014, 02:14 PM   #6
Ole Don
Ole Don's Avatar
At the Ford plant I worked at, the body guys used a 2x4 wrapped in carpet.
Old 02-23-2014, 10:17 AM   #7
frank long island
frank long island's Avatar
that would be my suggestion place 2x4 at bottom near lock striker and lay on troubled side may need to bounce as the metal used on these cars is heavier then todays cars was the trunk damaged on the side that is problem [accident] also you may be able to slot the lower striker catch this will bring it down on both sides and change the lower lines as mentioned above this with the forward movement might give you an acceptable solution
frank long island is offline   Reply With Quote
Old 02-23-2014, 05:35 PM   #8
s55mercury66
s55mercury66's Avatar
I will suggest that you also get it to fit as best you can with the striker removed. Then adjust the striker to latch properly. Sometimes the striker will hold panels all out of whack. Some guys will use them to align the panel when it is closed, but that will wear the latch and the striker out in short order.
Looking for bucket seats and rocker mouldings for full-size 1966 Mercury.
s55mercury66 is offline   Reply With Quote
Old 02-23-2014, 09:48 PM   #9
Dave72dt
I've got to agree with this as your first option for solving the problem. It really looks like something is keeping it from fully closing and the striker/latch would be the first I'd take out of the equation. Too thick or too firm of seal material can also keep it from closing properly.
Dave72dt is offline   Reply With Quote
Old 02-23-2014, 10:43 PM   #10
frank long island
dumb question did it fit before it looks as though you can go forward towards rear window hinges could be bent also
Old 02-24-2014, 02:02 PM   #11
CrownVic55
CrownVic55's Avatar
Did you do a frame off and if so, was body supported enough to keep the back end from sagging? From the pictures it looks like the back has dropped down. Also, if a frame off was done, the body pads may need to be tweaked to help raise the rear of the body. If trunk weatherstrip isn't new you could remove it and check fit with out the seal in case it is holding up fit in upper half of lid.
I did a frame off on 55 Crown and had to adjust the body pads since the body mounts were replaced.
Ben
CrownVic55 is offline   Reply With Quote
Old 02-24-2014, 02:45 PM   #12
ctfortner
ctfortner's Avatar
@crownvic55 - This was not a frame off this time, however back in the 90's when my dad and I did a half @ss restore on it we had the frame off. That was many moons ago, so as to the support question, I really dont know. We were both novices so my guess would be it wasnt supported as well as it could have been. The seal is new, however the shop that installed it after paint didnt get it perfectly aligned so with the current gap in there right now you can see daylight with it closed, meaning it would likely leak some. If the weatherstrop was aligned just right, it might have sealed, although not as good as if the trunk shut all the way down like it should. I think the trunk weatherstrip is pretty cheap so it may get pulled and redone while I work on this.
@frank - I dont remember it being that "off" but there were a lot of things that werent perfect before it went to the body shop. I need to dig out my pictures as I took them of everything before shipping it off, it may tell more.
@Dave & s55 - I did remove the lower latch which is 2 bolts and I could push it down further. It still wasnt perfect but better. I need to get a helper as it was hard to hold it down and look at the gaps. I will try this first and see. There is no more adjustment available in the latch currently, without modifying something.
I want to get it as close as I can with a good seal, but after the situation I went through (2 years of PAIN) with 2 body shops to get the paint job, I wont do anything right now that will affect the paint. The paint is FAR from perfect but I was without my car for 2 years (supposed to be 3 months) and barely got it back, lawyer involved etc, and at this point I want to get it together and drive it a little while
Old 02-24-2014, 06:35 PM   #13
s55mercury66
Yes, I remember the thread on the HAMB. I had a '56 Mainline painted dang near the same color as yours, back when I was a 17 year old know-it-all (1978). Good to see you are working on it, I really like '55-'56 FoRds. Big cars with round tail lights...yes.
Old 02-24-2014, 07:54 PM   #14
rick55
rick55's Avatar
I made the mistake of repairing the trunk lid and then painting the inside and not fully fitting it up. Don't know how or why, but my trunk lid looked like it didn't belong. Had to get the hammer out and knock it into shape. The thing to remember is that these old cars were made to be knocked and bent to shape. The metal is soft compared to today's cars and will fit with some gentle persuasion.
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 02-24-2014, 09:58 PM   #15
Daves55Sedan
Daves55Sedan's Avatar
My '55 doesn't have that much of a gap at the front of the deck lid. If you can loosen the bolts on your hinges and slide the deck lid forward about as much as it is sticking out in the back, that might help quite a bit.
Daves55Sedan is offline   Reply With Quote
Old 02-24-2014, 10:04 PM   #16
Daves55Sedan
It appears that you have excellent height adjustment already, so don't loosen the bolts that mount the hinges vertically. I would try loosening the bolts under the deck lid and then try to slide the lid forward on the hinges. Put a old piece of carpet or something between the lid and body to protect it in case you slide too far then carefully close without the carpet slowly to inspect alignment
Old 02-24-2014, 10:24 PM   #17
frank long island
you could also use masking tape on the edge I prefer the blue painters tape its less sticky and less likely to peel the paint
Old 02-24-2014, 10:44 PM   #18
ctfortner
ctfortner's Avatar
Out here fiddling with it. I loosened the bolts holding the lid to the hinge, it will actually slide forward some on the drivers side, actually a lot. I can slide it far enough that it would rub paint when closing. Pass side is tapped out, no room to slide forward.
Yall got me thinking about the seal. I removed the trunk latch again and I can push the lid down to be much closer to where it should be, but it has resistance if I dont force it. You cant see the seal good at the edge between the lid and windshield
but I was feeling it under there and the seal is all twisted under there. So the seal has a lip that should fit the lip of the car ( as yall know), but its twised in a manner that its just like having a 3/4" hunk of solid rubber in there when you close the lid. So I think the resistance (at least some of it) is the seal in there how it is.
I think the next step may be ripping out the seal and see where it is then. I know I can slide one side up to get real close, the other side needs work, maybe just making the hinge holes a hair longer.
Old 02-25-2014, 01:25 AM   #19
JeffB2
JeffB2's Avatar
If you used a Dennis Carpenter seal don't order another one,sadly they have been outsourcing get one from Steele Rubber all USA made.
JeffB2 is offline   Reply With Quote
Old 02-25-2014, 10:29 AM   #20
frank long island
how does the front edge line up with the cowl between window and trunk you may be able to raise the hinges from in the trunk to raise the front to clear the strip
