Old 12-29-2012, 04:15 PM   #1
mercman5519
Default 1966 289 ford motor into 1955 mercury
how hard of a project will this be ?
mercman5519 is offline   Reply With Quote
Old 12-29-2012, 06:56 PM   #2
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
Default Re: 1966 289 ford motor into 1955 mercury
Not very.
streetdreams is offline   Reply With Quote
Old 12-29-2012, 07:07 PM   #3
rick55
rick55's Avatar
Two words. Dead easy.
Regards
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 12-29-2012, 09:26 PM   #4
paul2748
paul2748's Avatar
As far as front mounts are concerned, you use stock Ford small block mounts. You may have to do some fabrication on the rear moiunt.
Old 12-29-2012, 11:30 PM   #5
JohnSunliner
JohnSunliner's Avatar
Just put a 302 (same size as 289) in 54 (same frame as 55). It is an easy fit.
JohnSunliner is offline   Reply With Quote
Old 12-30-2012, 04:17 PM   #6
darrell
you can use 64 galaxie mounts or 302 truck mounts.i have heard theres another set thats even a better fit.
darrell is offline   Reply With Quote
Old 12-30-2012, 10:54 PM   #7
parklane
parklane's Avatar
If you use Anchor # 2525, & 2526 (left & right) motor mounts, it will be high enough so you don't need to use washers to have engine clear crossmember. You also need a front sump oil pan.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 12-31-2012, 10:58 AM   #8
mercman5519
why would you need front sump oil pan,
Old 12-31-2012, 10:59 AM   #9
mercman5519
why would you need front sump pump oil pan ,
Old 12-31-2012, 03:22 PM   #10
darrell
you already have one.
Old 12-31-2012, 05:45 PM   #11
junkyardjeff
If your merc still has its original 292 I would be interested in it if its not junk and too far away.
junkyardjeff is offline   Reply With Quote
Old 12-31-2012, 08:38 PM   #12
mercman5519
I am in dunn nc and the casting numbers say that isa 1959 ford.
Old 12-31-2012, 09:00 PM   #13
junkyardjeff
I am looking for a 55 292 block
Old 12-31-2012, 09:22 PM   #14
streetdreams
How about a 312 short block assembly.
Old 12-31-2012, 09:37 PM   #15
junkyardjeff
I am kind of wanting to play the numbers game and have a 55 block but a 312 crank would be nice to put in a 292 block.
Old 01-01-2013, 09:16 AM   #16
streetdreams
Crank is .020/.020, bores are std at 3.80.
Old 01-04-2013, 11:18 AM   #17
mercman5519
1964galaxie motor mount has one bolt for chassis, mines have two will the one work.does it make a differance?
Old 01-04-2013, 06:00 PM   #18
Retro Jim
Retro Jim's Avatar
For the 312 crank to fit into a 292 block , the machinist will have to turn the mains down to fit into the 292 . Actually the 292 block will be much better than the 312 block and you won't have the crack problems from over torquing like the 312 had .
That way you will have a 292 but will have all the stock of the 312 !
Jim
Retro Jim is offline   Reply With Quote
