11-24-2014, 10:37 PM | #1 |
31 Coupe Body Wood Questions
Up front Guys, I have to tell you that I am a hot rodder. A "traditional" hot rodder. One of them. I usually hang out on the HAMB but occasionally come over to this side when I need some help with original Ford stuff.
Today, I need some help with the Ford Wood kit that I am in the process of installing in my chopped 1931 Model A standard coupe. My first question concerns the wood that goes around the rear window. As you can see, the uprights do not fit tightly into the dados on the cross pieces. Further, the the side pieces, when fitted to the cross pieces stand about 1/4" proud. Is this correct or should I deepen the dados when I shorten the uprights to accommodate the chop? My second question is easier to understand. What goes in the notch above the "B" post? I can't find anything in the box of hardware I collected when I took the old wood out. |
11-25-2014, 09:49 AM | #2 |
Re: 31 Coupe Body Wood Questions
The window frame uprights fit flush. They hold the window shade brackets. There is no notch between the B pillar upright and the roof line. They fit flush to the upper wood. That's all there is.
Enjoy yer day. Tom Hate can't fix what it started. Last edited by A bones; 11-25-2014 at 09:47 PM. Reason: My bad |
11-25-2014, 09:51 AM | #3 |
The biggest thing you are experiencing is poor craftsmanship. The wood in your pictures is not accurately cut. Matter of fact, the dado you speak of is not either. Also all of the wood joints should make a smooth transition to the next adjoin piece or otherwise the upholstery will have a bulge in that area.
11-25-2014, 02:13 PM | #4 |
Thanks Guys!
A bones - I am recreating the hot rod that I had in 1958. The Model A that I bought had been offered for sale a number of times over the years with no takers. The price was reasonable but the body needed a lot of work and it is not a gem by any means. All things considered, I have put an irrational amount of money into this body. For less than what I have spent so far I could have purchased a nicely restored coupe and cut it up. I don't know if this will make you feel better but I sold the complete chassis, radiator and shell, fenders, running boards, and hood to a local restorer. By trade, he is a cabinet maker and these parts will return to the road with a "woody" body. |
11-25-2014, 10:02 PM | #5 |
Enjoy yer day. Tom Hate can't fix what it started. |
