11-25-2014, 09:40 AM | #21 | |
Re: Fender well spare tires............
Yes, they are at the Benson Research Center (Archives). I think there is 7 different versions (drawings) of the 1928-29 fender including Service Replacement. You really do not need the print to make the filler panel, you just need to have the ability to fabricate a reverse curved panel. He is basically how we do it... . (The 2nd picture shows the panel already made and the fender is bolted into position as the panel is TIG welded into position and then planished.) (The numbers on the 4th & 5th picture are the corresponding radii that the panel is stretched to.) . |
11-25-2014, 11:27 AM | #22 |
I have twins on my 30 peekup, and the Firestones (6 years old) are tight, but I can put them in and remove them without deflating them.
11-25-2014, 12:26 PM | #23 |
Brent, I do believe you are correct! My Firestone tires measure 5 3/ 4” at the widest point when inflated. The wheel wells on my car measure 6 1/ 4” wide at the fender, but are bowed in where the widest part of the tire sets in the well to 5 5/ 8”. Any ideas on how to remove the bow without breaking the well loose from the fender?
11-25-2014, 01:16 PM | #24 |
my experience was not the same as mr. terry's. i had some 19" firestones that would not fit in an original wheel well when inflated. i called coker tire and asked whoever answered the fone, that if these tires were made in original molds, as i had been led to believe they were, why they wouldn't fit. his answer was "i dunno".
11-25-2014, 05:46 PM | #25 | |
Now what the Coker representative did not tell you. Coker is making their Firestone 4.50/5.00-19" tires with original moulds however it is to an original 5.00-19 size, ...and the original Model-A passenger vehicle originally used 4.75-19. While this might seem like a simple answer to the fitting issue, the truth is Ford used that same size (5.00-19") tire on their Station Wagons, ...which also used the side-mounted spare. Therefore the fender tire well was engineered to be used unilaterally between both size tires. That is why the Coker manufactured 19" Firestone will indeed fit the original fender well without deflating it. , |
11-25-2014, 07:18 PM | #26 |
11-25-2014, 07:31 PM | #27 |
I have a new old stock 2 piece rear tire cover that will not fit a new Firestone tire deflated or even off the rim, but fits like a glove on a 40 year old Goodyear with air in it.
11-25-2014, 11:36 PM | #28 |
Thank you Brent, for the information. That's going to be a lot of work, have two fenders to work.
