Old 12-17-2014, 01:14 PM   #1
Skeezixx
Skeezixx's Avatar
Default What's left to check?
Two weeks ago I pulled my 29 roadster about 10' out of the garage to change an overhead light. When I started it up again to pull it back in it ran for a few seconds then stalled.....repeatedly.
Suspecting fuel flow problems I checked the screen in the sediment bowl which was clean. I removed the fuel line at the carb and had good flow.
I am running a modern Zenith tractor carb which, till now, never gave me a problem. I removed it and replaced it with a known good original Zenith. The car wouldn't even start. I then disassembled another known to be good spare Zenith 2 and sprayed it's insides with carb cleaner, floral wire, air etc.. I put it on and it didn't start. A friend with a 30 Tudor drove up and allowed me to remove his carb (still hot from running) holding it with a towel. I installed it on my car and it popped and coughed but didn't start. I replaced my Zenith tractor carb and it would run for a few seconds then stop again.
The timing was spot on but that didn't stop me from setting it yet again. The car had new points and condenser about a month ago but being desperate I changed them also using my spares still in sealed Snyder's bags. No difference. I tried three distributor caps. nothing. The plugs, Champion 3Xs, looked very clean.
I resorted to Les Andrews red book where he mentions leaking manifolds causing problems. I inspected the gaskets but saw no obvious evidence of a leak so I put my torque wrench on all the bolts and they were all torqued to 30 lbs.
I'm flummoxed guys. Does anyone have any idea what I should check next?
Skeezixx is offline   Reply With Quote
Old 12-17-2014, 01:16 PM   #2
Mitch//pa
Default Re: What's left to check?
do you have a continuos strong blue spark???????
Old 12-17-2014, 01:53 PM   #3
Skeezixx
Skeezixx's Avatar
Good question. I'm not at the car now but I'll check. At which point? The coil, the points, the plugs?
BTW: About 4 months ago I left the key on and had to replace the coil so it's relatively new.
Old 12-17-2014, 01:57 PM   #4
Mitch//pa
start with checking it at the end of the coil wire to a head nut when it is not starting
Old 12-17-2014, 02:04 PM   #5
Fullraceflathead
Fullraceflathead's Avatar
If you left the Key on and fried the coil the points most likely are damaged as well.
Fullraceflathead is offline   Reply With Quote
Old 12-17-2014, 02:09 PM   #6
Mitch//pa
he states that the coil was replaced after leaving the key on
but not sure if that inlcd points also
Old 12-17-2014, 02:13 PM   #7
hardtimes
hardtimes's Avatar
X2...as if points were closed , when coil was fried, other damage (points/cond) should be suspect for damage as well
hardtimes is offline   Reply With Quote
Old 12-17-2014, 03:25 PM   #8
pooch
pooch's Avatar
Hook a timing light to coil wire and wind motor over and check for an even flashing of light .
pooch is offline   Reply With Quote
Old 12-17-2014, 03:32 PM   #9
Patrick L.
Patrick L.'s Avatar
end quote
Sounds like they were changed.
As said, check for spark. Like Mitch said, hold coil wire 1/4" from good ground and spin the engine. If there is spark, thats not your problem. If there isn't then thats your problem and you need to start at the beginning by looking for 6v from the beginning all the way to the points and a good ground thru them.
Old 12-17-2014, 04:13 PM   #10
Tom Wesenberg
Tom Wesenberg's Avatar
I would check for spark first. Also the plugs might look good but might be fouled from the short drive out of the garage. Hold the coil wire 1/4" out of the distributor cap and see if it starts. If it does, let it set there and reach full temp, then slowly push the wire into place and hope the plugs keep firing.
Old 12-17-2014, 04:22 PM   #11
Fred K-OR
Fred K-OR's Avatar
Gas valve not open enough???
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 12-17-2014, 05:02 PM   #12
Patrick L.
Patrick L.'s Avatar
To go along with what Tom said, a short piece of vacuum line will work for that. Just an old trick to save use of an extra hand or a zap and resultant banging of the head on the hood.
Old 12-17-2014, 07:26 PM   #13
Skeezixx
Skeezixx's Avatar
Points-new
Coil- 5 months old (sparking when grounded near a head bolt)
Condenser -new (two tried)
I have another set of 3Xs I can try but the ones in there are sparking when removed and grounded against the head.
The only modification in the timing link is that I installed a Nu-Rex automatic advance gadget about a year ago. If it malfunctioned and got stuck on full advance or such perhaps that's my problem.
If none of the regular fixes work (so far not) Then I guess as a diagnostic test I'll remove the Nu-Rex gizmo and see if there's a difference this weekend.
Stay tuned (pun intended)
Old 12-17-2014, 07:29 PM   #14
Skeezixx
Skeezixx's Avatar
This is about the only thing I haven't tried but I'll give it a go!
Old 12-17-2014, 07:37 PM   #15
Skeezixx
Skeezixx's Avatar
I bought a timing light timing kit and read somewhere I needed a 6V timing light. Is this true (for both your suggestion and timing). I have an old 12V one.
(somewhere around here I have a timing light from a 50s BMW motorcycle. I have been waiting to unearth it before using the timing kit).
Old 12-17-2014, 07:39 PM   #16
Skeezixx
Skeezixx's Avatar
I have remembered to turn on the gas valve often enough during this latest tribulation that it can be excluded as the problem.
Old 12-17-2014, 08:05 PM   #17
Synchro909
Synchro909's Avatar
Talking Re: What's left to check?
Tighten the left hand rear axle nut!!!!
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 12-17-2014, 08:43 PM   #18
Kahuna
Kahuna's Avatar
When you switched carbs, did you take a moment and make sure fuel was flowing when the carb(s) were disconnected?
Just a thought
Kahuna is offline   Reply With Quote
Old 12-17-2014, 09:06 PM   #19
Skeezixx
Skeezixx's Avatar
Just a thought
Yep because they all flooded
Old 12-17-2014, 09:12 PM   #20
Mitch//pa
maybe the mice built a condo in your exhaust and plugged it solid
