12-17-2014, 11:31 AM | #1 |
PU Radiator Shell
I saw this on eBay this morning. It's on a '31 CCPU. Is that the shell that was used on Pickups or is that an AA shell?
12-17-2014, 11:36 AM | #2 |
Re: PU Radiator Shell
It's AA.
12-17-2014, 11:38 AM | #3 |
That is a 28-29 radiator shell with a candian emblem on it.
12-17-2014, 11:43 AM | #4 |
It's on a '31 Pickup.
12-17-2014, 11:43 AM | #5 |
That's a 31 AA shell.
Bob |
12-17-2014, 12:46 PM | #6 |
Registered User
it has a correct 31 emblem on it this type of emblem was used after March 1931, all 30s that used this shell and early 31s used the blue enameled emblems these shells were magnetic steel and painted gloss black some ,on deluxe AA trucks were stainless,but they had the same flat top they took a thicker core radiator, so the shell was thicker to accommodate it the pickups had a steel shell painted black,except for the deluxe models which had the stainless shells,the emblems match the years for the cars in the 3rd and 4th photos you can see where the hole is for the radiator fill pipe, the second photo shows the difference in thickness in the first photo the AA is on the left ,and the pickup is on the right tom |
12-17-2014, 01:50 PM | #7 |
With all due respect how can it be both ? Wayne
12-17-2014, 02:44 PM | #8 |
It isn't. Mot is right.
12-17-2014, 03:04 PM | #9 |
Also take a look at the bottom area around crank hole..
12-17-2014, 03:07 PM | #10 | |
below is the text on page 15-8 Revised 1997 RG&JS "In 1930, the passenger car radiator shell was changed to stainless steel with a black painted steel panel in the lower section. With the introduction of the Victoria in November 1930, the upper section became a steel insert. A later design had a similar painted insert at the bottom. Both designs were used with 1931 cars. The upper panel was painted the lower body color, while the lower panel was either black or the lower body color. The commercial shell was magnetic steel painted black except for Deluxe 1930-31 models. A blue vitreous enamel emblem was used on the 1928 through 1930 radiator shells. The non-enameled portions were unpolished nickel plating through 1929 and dull chrome thereafter. The 1928 emblem had a stepped edge, whereas the 1929-1930 emblems had a chamfered edge. With the introduction of the 1931 style shell the emblem was changed to a stainless steel stamping with black paint in the recesses. Some stamped emblems used between late 1930 and March 1931 had blue paint in the recesses." Don
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
12-17-2014, 03:51 PM | #11 |
The easiest way for me to tell is to look for the little point hanging down under the emblem.Point=pickup.Straight=AA.Plus,it is a little thicker.I have an ad out locally looking to trade a nice 31 passenger car shell for a steel pickup one.I've had a lot of offers of the AA shells,but no pickup shells.I had a fellow show up Sunday with what he claimed was a pickup shell,I pointed out that it was AA with the straight edge.What threw me,and made him believe it was a pickup shell was it is the same thickness as a passenger car or pickup shell.We compared an AA shell I have with his and his is a half inch thinner than mine.Now we don't know what he has.
12-17-2014, 05:28 PM | #12 |
Registered User
don
I was just trying to clarify what he asked it was not a tutorial on all radiator shells all the answers are in the JS the emblem is not a Canadian one its the common 1931 emblem which was used after March 1931 I just tried to show the difference between the pick up shell and the AA shell the shells are not interchangeable they have different radiators I tried to show the different location of the hole for the radiator fill I don't feel like dragging the heavy AA radiator out from the barn to take a photo of it its about twice as heavy as the A radiator this is taken right out of the JS for the heavy commercial section THIS ONLY APPLIES TO THE AAs this should answer all questions about the shell in question tom |
12-17-2014, 06:03 PM | #13 | |
Don
12-17-2014, 07:08 PM | #14 |
Thanks to all who responded, especially "MOT" (Tom) with his pictures and explanations.
12-17-2014, 07:54 PM | #15 | |
An AA "straight" in-line on a A shell. Joe K
Shudda kept the horse. |
12-17-2014, 10:31 PM | #16 |
Joe, where did you get that quote? I'd like to see pix of the narrower shell.
12-18-2014, 06:23 AM | #17 | |
Joe K
12-18-2014, 08:01 AM | #18 |
At some point I may end up owning that shell.He wants to do some digging around on just what it is.I'll try to get a picture of it,but I can no longer post them here.None of my pictures will post here,even the ones I've posted in the past.
Thread Tools | |
Display Modes | |
