Old 12-17-2014, 02:15 PM   #41
wensum
wensum's Avatar
Red face Re: Pressurized oiling system.
Originally Posted by Mike V. Florida View Post
As Bob C said, that's the hole the distributor shaft comes down to mate with the oil pump drive bearing and gear.
Oops, bungled there!
Thought I was being observant but in fact showed my lack of knowledge.
I'm a little bit wiser!
Keith
wensum is offline   Reply With Quote
Old 12-17-2014, 05:03 PM   #42
hardtimes
hardtimes's Avatar
Default Re: Pressurized oiling system.
Hey Keith,
Well, I think that you are observant ! At least , you got me to take closer look at my posted picture. Although not my A block, but belongs to someone that I know, it can be improved in that gasket area. After making the block VERY clean in that area, JB Weld would restore the broken out gasket surface.
But, this area is not critical for sealing as bottom of valve chamber.
hardtimes is offline   Reply With Quote
Old 12-18-2014, 11:45 AM   #43
Jordan
Jordan's Avatar
The car could be using one of those distributors driven off the timing gear. I saw a setup like this on an A400 for sale at Pate Swap meet last year. It was a neat set up.
Cowtown A's
Jordan is offline   Reply With Quote
Old 12-18-2014, 01:35 PM   #44
hardtimes
hardtimes's Avatar
Hey Jordan,
Did you get a picture of that setup that you can share ?
C. Yapp makes or made a front timing cover setup where a front driven distributor is mounted, wonder if it was that make ?
