12-17-2014, 09:26 PM | #21 |
Re: What's left to check?
12-17-2014, 09:29 PM | #22 |
Something wrong with the nurex modification, also loosen the gas cap.
Bob |
12-17-2014, 10:07 PM | #23 |
I just found a new one, if the shielded cable coming from ignition switch is screwed in to distributor just a hair too much it grounds out..not all the time but intermittently... backed it out and no more problems..
The only thing worth learning is what you learn after you know it all !! |
12-18-2014, 01:20 AM | #24 |
12-18-2014, 01:43 AM | #25 |
The ignition cable hasn't been tightened or loosened since I put the engine together in July of last year but it's a consideration. Can't hurt to try.
12-18-2014, 01:49 AM | #26 |
12-18-2014, 02:15 AM | #27 | |
Check for good spark, then try the fouled plug trick. |
12-18-2014, 11:10 AM | #28 |
A MISH-MASH trouble shooting "SEQUENCE"?? like this can lead to more confusion & probably creating more problems, while switching to known "GOOD" parts!!! What happened to COMMON SENSE REASONING.
Sometimes, a simple thing like this leads to 7 pages of posts & NO definite conclusion!! Bill W.
12-18-2014, 02:46 PM | #29 |
Well said bill
12-18-2014, 04:32 PM | #30 |
IF YOU TIMING WERE STUCK ADVANCED YOU WOULD GET A SERIOUS KICK BACK WHEN CRANKING. Ops sorry about the caps! From changing all these carbs I would kinda lean towards an ignition problem When you hold your palm over the air intake check how well the carb is sucking. That should at least tell you if the manifold is seated to the gaskets well to rule that out. YOU NEED FUEL, Air , timed spark. Some times new parts that are craply built fail rather quickly. Ignition parts especially prone here. Also the wire inside the distributor is problematic on the Model A distributor.
12-18-2014, 05:49 PM | #31 |
I had opportunity to visit the car briefly earlier today. I found a very intermittent spark from the coil. Going to change the coil and see what happens.
12-19-2014, 10:14 AM | #32 | |
Bill W.
12-20-2014, 04:34 PM | #33 |
Replaced the coil with a new 6V one from O'Reillys and though the wire on the + side is hot I get no spark from the coil.
12-20-2014, 04:48 PM | #34 |
with the points in the OPEN position you should have power at both poles on the coil.
you should also have power at the movable point arm with the key ON and points still OPEN. you can also place a credit card between the comtacts to make the check easier. ck and report Last edited by Mitch//pa; 12-20-2014 at 05:22 PM. |
12-21-2014, 03:08 AM | #35 | |
Thanks Mitch. Will do. |
12-21-2014, 04:53 AM | #36 | |
Wayne |
12-21-2014, 05:36 AM | #37 | |
12-21-2014, 08:54 AM | #38 |
Yeah, I have a 12V transformer I could use with the timing light. I was just stalling because I know I have an old BMW 6V one around here someplace (probably right next to the set of ignition wrenches I also can't find). I was just waiting for it to resurface.
12-21-2014, 10:43 AM | #39 |
I have a 12 volt timing light that also works on 6 volts. You should give your's a try, and might get lucky.
12-21-2014, 11:58 AM | #40 |
Sounds like the kind of thing that happens when a person changes to the so called modern points, especially when the wireless lower plate is also used. If this is the case put the original breaker plate and points back in and the problem will more than likely be solved. I've actually seen cases where people would rather have problems than change back to the simple, dependable, original setup . Another possibility is a short in the terminal box. I once ran a metal conduit from the generator to the terminal box on my september 29 . The conduit shorted against the left terminan in the terminal box and eventually burned the wires all the way to the ammeter. at first it still ran but backfired a lot. when it burned up the ammeter untill the posts were loose it wouldn't run any more. I replaced the wiring and ammeter, threw away the metal conduit and all has been good since. Good luck.
