08-31-2015, 04:24 PM | #1 |
Compression test vs Leak down test
I ran a compression test on my stock A and the range was from 62 to 65 pounds. Then I ran a leak down test and all the cylinders were different with one only registering 18 pounds with 40 applied. Can anyone explain why one test was OK while the other was poor. Thanks for any help.
08-31-2015, 04:56 PM | #2 |
Re: Compression test vs Leak down test
Was the engine held at TDC on compression stroke for each cylinder ?
Where was it leaking from, intake,exhuast,crankcase |
08-31-2015, 05:55 PM | #3 | |
A compression test will tell you if you have a problem, A leakdown test will tell where the problem is. Bill |
08-31-2015, 06:00 PM | #4 | |
08-31-2015, 06:29 PM | #5 |
I did have the cylinders on TDC but I only used 40 LBS. I could hear the leak coming from the intake. One cylinder held 30 LBS and the worst was only 18 LBS. I guess my intake valves are leaking some but the compression test seemed good.
08-31-2015, 06:39 PM | #6 |
40# on the leak test is fine. If you heard the leak on all cylinders from the intake I still don't think I'd worry about it. It does seem as though the engine rolled a bit when the air was applied. Just to be on the safe side I think I'd check the lash. |
08-31-2015, 08:26 PM | #7 |
I'll check the lash. Thanks for the help.
