Old 03-21-2014, 05:15 AM   #1
BobbyG
BobbyG's Avatar
Default Backing up in the dark
I was out in the 28 coupe late last night and found myself on an unlit road where I had to back up to turn around, as I looked over my shoulder to look out the back I could see nothing but the reflection from the front.
It was like the upright front & rear screens were bouncing against each other like mirrors, very strange to see.
In the end I had to turn the headlights off and back up using the flash of my indicators.
Thinking about fitting a reversing light on the back as I don't want to dent her driving backwards in the dark.
Anyone else had similiar?
BobbyG is offline   Reply With Quote
Old 03-21-2014, 06:05 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Backing up in the dark
The light from my tail/license light lights the road quite well.
Old 03-21-2014, 07:14 AM   #3
Ray64
Ray64's Avatar
I think that is caused because the front windshield is on the vertical.
Ray64 is offline   Reply With Quote
Old 03-21-2014, 07:18 AM   #4
Patrick L.
Patrick L.'s Avatar
When you feel the car go bump in the dark, just push on the middle pedal. [ smiley face]
Old 03-21-2014, 08:03 AM   #5
dave in australia
Never thought about it before, mainly because I haven't been in this situation yet. Thanks for mentioning this, and now I'll look into fitting something onto my tudor.
dave in australia is offline   Reply With Quote
Old 03-21-2014, 08:20 AM   #6
Growley bear
Try turning of your headlights and/or open the wind screen a bit.
Chet
Growley bear is offline   Reply With Quote
Old 03-21-2014, 09:52 AM   #7
eagle
eagle's Avatar
Open your door window and look back out the open window. Most necks will swivel enough to use in that manner... Ha! The reflecting glass of the windshield/rear glass won't be helped much with backup lights. Takes some geting used to when cars pass in the night they appear to come and go from every direction. You soon get used to it.
eagle is offline   Reply With Quote
Old 03-21-2014, 10:42 AM   #8
Mitch//pa
install a rear backup camera
Old 03-21-2014, 11:09 AM   #9
700rpm
700rpm's Avatar
Just swing your windshield open a bit so it isn't vertical.
Ray Horton, Portland, OR
Old 03-21-2014, 11:31 AM   #10
Tom Wesenberg
That's a good idea. My friend installed one in his Town Sedan. At some point I hope to buy one also.
Old 03-21-2014, 11:47 AM   #11
junk yard kid
I just look where i plan to back up before i back up.
junk yard kid is offline   Reply With Quote
Old 03-21-2014, 12:11 PM   #12
Bruce Lancaster
Retard the spark and turn the GAV a couple turns toward rich...the flames out exhaust should either eliminate or illuminate anything back there. Henry thought of everything.
Bruce Lancaster is offline   Reply With Quote
Old 03-21-2014, 12:37 PM   #13
CarlG
CarlG's Avatar
I've got back-up lights, just haven't got around to hooking them up yet.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-21-2014, 03:25 PM   #14
Michael M
Michael M's Avatar
I assume that Bruce's suggestion would help with tailgaters as well! Lol
Michael M is offline   Reply With Quote
Old 03-21-2014, 03:27 PM   #15
Bill in Al
Bill in Al's Avatar
I find the shade when pulled down at night will help that problem of light reflecting and not block my view of following vehicles.
Bill in Al is offline   Reply With Quote
Old 03-21-2014, 03:51 PM   #16
Bruce Adams
Bruce Adams's Avatar
I was just thinking of those $2.50 LED lights with a magnet on the back that Harbor Freight sells and how they would let me back down a long driveway or whatever.
Have to be put on the bumper and off, though, but worth keeping around for the occasional sticky backing up situation.
Bruce Adams is offline   Reply With Quote
Old 03-21-2014, 05:02 PM   #17
bettlesr
bettlesr's Avatar
I got two pair of high power LEDs in a "bolt type " housing. They really light up whats behind the car. As I have an F150 trans it has a backup light switch built in. I used the threaded end to hold on the license plate. I then ran the wires behind the plate holder and glued them in place. I think these are only 12v, not sure.
1965 Lotus Elan S2
1930 Model A Sport Coupe
bettlesr is offline   Reply With Quote
Old 03-21-2014, 07:54 PM   #18
w.michael
w.michael's Avatar
It was broad DAYLIGHT when I backed into a brick abutment and crunched the rear fender and bumperette. I don't think the backup light would have provided much protection. I even punched a hole in my new Blue Ridge Parkway license plate.
W. Michael
w.michael is offline   Reply With Quote
Old 03-22-2014, 02:41 AM   #19
BobbyG
BobbyG's Avatar
W. Michael
Oh man I bet that plate wasn't the only thing that was blue right then eh !
Old 03-22-2014, 09:15 AM   #20
V4F
V4F's Avatar
my back window is slightly tinted & stops the glare from behind . my license plate lite is led & plenty bright to back up on a dark street .
V4f
V4F is offline   Reply With Quote
