03-08-2024, 11:02 AM | #1 |
Flathead bearings - red/blue sizes?
Hi All,
I'm going through a few boxes of flathead bearings and found several with odd dimensions. For example, I've got a set labeled "ICM-6333-A Red .0852-.0855 and Blue .0855-.0858" Can anyone explain the color/sizing? I've never run across these before and am not finding anything in my books. |
03-08-2024, 11:48 AM | #2 |
Re: Flathead bearings - red/blue sizes?
Std bearing thickness is .0852, so these could be used on a slightly undersized journal
03-08-2024, 11:51 AM | #3 |
Ahh, thanks! I wasn't considering the shell thickness. Were odd journal sizes really that common? I've come across piles of bearings over the years but never the reds and blues.
03-08-2024, 12:15 PM | #4 |
1CM-6333-B (Red Size) crankshaft dia 2.498"/ 2.499 (Std) Block main Bearing Bore 2.675"/2.671" (Std) Overall Length 1.49"/1.506" (Std) It shows the same dimensions for 1CM-6333-C (Blue Size) |
