Old 04-10-2021, 06:12 AM   #121
38 coupe
38 coupe's Avatar
Default Re: Engine block I.D. pictures
Here are the 35-36 pictures. Again, with thanks to others on this thread.
Old 04-10-2021, 06:19 AM   #122
38 coupe
38 coupe's Avatar
Here are the LB pictures. I realize I don't have a picture of the main bearing stud spacing (looks about 3 1/4 when measuring center to center with your tape measure or scale), which is my go-to way of IDing an LB. This deficiency is particularly egregious since I could have done so last month at the Chickashaw swap meet. My apologies.
In the picture with the two oil pans the left pan is from an LB and the right pan is from a Babbitt motor.
Old 04-10-2021, 06:21 AM   #123
38 coupe
38 coupe's Avatar
Here are the 37-38 late 21 stud pictures.
Old 04-10-2021, 06:24 AM   #124
38 coupe
38 coupe's Avatar
Here is the 1938 only 24 stud picture (note short crank, 24 studs, and pencil test):
Old 04-10-2021, 06:27 AM   #125
38 coupe
38 coupe's Avatar
Here are the 39-40 Ford (221 cubic inches) pictures:
Old 04-10-2021, 06:29 AM   #126
38 coupe
38 coupe's Avatar
Here are the 39-40 Mercury (239 cubic inches) pictures:
Old 04-10-2021, 06:45 AM   #127
38 coupe
38 coupe's Avatar
Here are the 41-42 Ford (221 cubic inches) pictures:
I don't have a picture yet! Working on it...
Old 04-10-2021, 06:56 AM   #128
old Tom
Originally Posted by 38 coupe View Post
what is the proper name for those plugs? Most of my reference literature is actually my dad's reference literature and lives at my folk's house. I did not find a part number and description for the plugs in the green book, the only parts book i have at my house, so i referred to them by the name i have heard them called.
Davidg is right, that book is a bargain for what you get.
core clean out plugs
old Tom is offline   Reply With Quote
Old 04-10-2021, 06:56 AM   #129
old Tom
Core clean out plugs
Old 04-10-2021, 07:10 AM   #130
38 coupe
38 coupe's Avatar
Here are pictures of 41-42 Mercury (239 cubic inch) blocks:
Old 04-10-2021, 07:12 AM   #131
38 coupe
38 coupe's Avatar
I don't have pictures of World War 2 era blocks. Instead I'll post pictures of two blocks damaged by hanging them only from the thin cast on bell housing from modern engine stands. I'm not saying this will happen to your engine if you do this, but it might.
Old 04-10-2021, 07:16 AM   #132
38 coupe
38 coupe's Avatar
Here are pictures of "59 series" 46-48 engines:
Old 04-10-2021, 07:18 AM   #133
38 coupe
38 coupe's Avatar
Here are pictures of 49-53 8BA blocks:
Old 04-10-2021, 07:47 AM   #134
jimTN
Cannot get any of the pics to enlarge, when clicked on, this msg comes up:
<Error>
<Code>AccessDenied</Code>
<Message>Access Denied</Message>
<RequestId>33KWSJ9Z8RTVGNJE</RequestId>
<HostId>EoZtdOwJKaR9UxBoeFMQYGY2l7X/ZHNCeHEF56kTgPMRkahg8oLki7f0yItrjlEmpvvt0q/B19A=</HostId>
</Error>
jimTN is online now   Reply With Quote
Old 04-10-2021, 07:52 AM   #135
jimTN
Opps, see further down 28 cpe corrected the problem with new pics.
