Old 09-22-2010, 12:33 PM   #1
55Crown
Default Voltage Regulator
Can I use a regulator of a higher amp rating on my 6 volt 55 Crown. The car had a 40 amp originally and I would like to replace it with a 50 amp nos one I got. The original one is not functioning properly, that's why it needs replacing.
55Crown is offline   Reply With Quote
Old 09-22-2010, 08:27 PM   #2
parklane
parklane's Avatar
Default Re: Voltage Regulator
Can't think back that far without hurting myself, but welcome to the site.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 09-25-2010, 06:55 PM   #3
rick55
rick55's Avatar
Voltage regulators are interchangeable and what you want to do is OK.
They operate on voltage not amperage.
You may need to set it though. It is a case of suck it and see!
You say the old one is not working properly, it probably just needs cleaning up and resetting also. The springs on the contacts do give way after a while - 55 years isn't bad though.
Regards
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
