10-18-2012, 10:11 AM | #1 |
.10 - .10 - .10?
I have a '59' engine that was rebuilt by a Ford authorized rebuilder in '60. It is marked as .10 - .10 - .10. What the heck does the third .10 relate to?
10-18-2012, 10:25 AM | #2 |
Re: .10 - .10 - .10?
Rods, mains, cylinders ???
-WANTED-
Pre-War Speed Equipment Davies or Morrison Intake Manifold 77-6050B, 81AS - 81SB - 99AS - 99SB 19AS cylinder heads |
10-18-2012, 10:36 AM | #3 |
10-18-2012, 11:29 AM | #4 |
Wasn't 10-10-10 a couple years ago ? We get the final in the set this year 12-12-12 .
10-18-2012, 12:08 PM | #5 |
10 Mains--10 Rods-- I've never seen 10 pistons. Most pistons ar 20-30- 40- 60-80-100-125 ect. Walt
10-18-2012, 12:28 PM | #6 |
10-18-2012, 01:02 PM | #7 |
10-18-2012, 01:34 PM | #8 |
Like Walt says, .010 is an odd overbore size. Maybe cam bearings?? OMO
10-18-2012, 01:37 PM | #9 |
I know 10 10 10 fertilizer will work wonders in your garden ?
10-18-2012, 02:04 PM | #10 |
"10 Mains--10 Rods-- I've never seen 10 pistons. Most pistons ar 20-30- 40- 60-80-100-125 ect. Walt"
_______________ My little flattie is the original 221 and the bore is: .045 over. And supposedly a Ford rebuilt size. JW |
10-18-2012, 03:36 PM | #11 |
Back in the day, you could find Chrysler products with this kind of undersize in their engines. Ford Industrial engine rebuilders in Patterson, went to .030 or .040 ( I forget which) only on Flatheads. If they didn't clean up they junked them. In the late 60's I was in their warehouse and saw hundresa of then on shelves waiting for delivery to ?? They had been rebuilt for Sears. They didn't rebuild Mercury (8CM) engines and discarted the 4" cranks. sold them to other rebuilders, I think. Saw a shelf full of them too, but our racing association wouldn't allow them.
Ahhh, memories. |
10-18-2012, 03:43 PM | #12 |
It isn't the cylinders. They were bored and then sleeved back to standard by the rebuilder.
10-18-2012, 03:53 PM | #13 |
Guy had a stutter ! Zeke
Only problem with retirement is never a day off |
10-18-2012, 04:30 PM | #14 |
Maby it was .100-.010-.010. If they put sleeves in they still had to bore it for the sleeves. Just another guess.
10-18-2012, 05:11 PM | #15 |
You could take it apart and measure it??
10-18-2012, 05:26 PM | #16 |
This was acheived by peeling out the steel sleeves and honing for .043 pistons. Very common.
10-18-2012, 06:21 PM | #17 |
these had floating bearings, could it be mains, rods , crank ? not a statement question .
10-18-2012, 06:38 PM | #18 |
LOL. Yes. It comes with advancing senility. I sought treatment, but it didn't help the stutter, only made my nose grow.
gerrald meacham - "these had floating bearings..." One would think so. But actually, this engine was rebuilt with 49-53 type crank and rods: individual bearings. Perhaps by 1960, rebuilders were doing this. This one was done by Fred Jones of Oklahoma City. |
10-18-2012, 07:36 PM | #19 |
In looking at the Ford Bible, Ford made some pistons in .0025 and .005 oversize, In the late 70s when I worked in a Ford dealership they refered to pistons as Red are Blue which designated an oversize, I don't know what red oversize or blue oversize translated to in size. I Googled it and came up with this referance to it http://www.428cobrajet.org/id-piston I think i was working on a 351M at the time, I know it was not a 428 Cobra Jet for what it is worth. Brian
10-18-2012, 10:59 PM | #20 |
Only way to know what you've got is to measure everything up. However, would the third 'ten' refer to thrust faces being 10 thou wider?
