Old 03-08-2024, 11:02 AM   #1
onthehunt
onthehunt's Avatar
Default Flathead bearings - red/blue sizes?
Hi All,
I'm going through a few boxes of flathead bearings and found several with odd dimensions.
For example, I've got a set labeled "ICM-6333-A Red .0852-.0855 and Blue .0855-.0858"
Can anyone explain the color/sizing? I've never run across these before and am not finding anything in my books.
onthehunt is offline   Reply With Quote
Old 03-08-2024, 11:48 AM   #2
flatjack9
flatjack9's Avatar
Default Re: Flathead bearings - red/blue sizes?
Std bearing thickness is .0852, so these could be used on a slightly undersized journal
Old 03-08-2024, 11:51 AM   #3
onthehunt
onthehunt's Avatar
Ahh, thanks! I wasn't considering the shell thickness. Were odd journal sizes really that common? I've come across piles of bearings over the years but never the reds and blues.
Old 03-08-2024, 12:15 PM   #4
Bob C
This is from 1949-53 Mercury parts book.
1CM-6333-B (Red Size) crankshaft dia 2.498"/ 2.499 (Std)
Block main Bearing Bore 2.675"/2.671" (Std) Overall Length
1.49"/1.506" (Std)
It shows the same dimensions for 1CM-6333-C (Blue Size)
