Old 03-14-2024, 10:49 AM   #21
Bored&Stroked
Bored&Stroked's Avatar
Default Re: New Eddie Myers’s heads question
Hmmmm . . . I would next accurately measure the crankshaft stroke.
Something seems weird in that you're running a very "normal" setup --> with a 4.00" Merc crank. I would also measure exactly how high the top of the dome of the piston is above the deck. The heads look about "normal" in the dome areas. Would also like to know the depth of the dome/pocket in the center of the head.
Measure a piston on both sides of the block. Once we know the stroke and the height of the piston dome, then we can figure out what to do next. If the piston locations (to the deck) are consistent on both sides, then maybe the pistons are for a 4 1/8" stroke compression height. This would result in the piston being .0625 further down than it should be. If the piston was .0625 higher, then things would be a lot closer to how they should be (squish). The piston definitely should not be "down in the hole" as it is.
Also, while the engine will run - I would surely want the piston/squish situation to be "fixed" if it was mine. It will be a "dog" as it is currently configured.
Companies make mistakes - maybe the pistons were manufactured or boxed incorrectly?
Old 03-14-2024, 11:13 AM   #22
Tim Ayers
I'm kind of thinking the same, Dale. It seems to me like it's got the wrong pistons in it.
Old 03-14-2024, 11:27 AM   #23
Bored&Stroked
Yeah Tim - that is my guess as well.
Old 03-14-2024, 01:02 PM   #24
V8COOPMAN
V8COOPMAN's Avatar
More of John's pics that he sent this morning.
Coop
Click Links Below __
T5 W/TORQUE TUBE
Old 03-14-2024, 01:15 PM   #25
Tim Ayers
That piston position looks fine to me. Something is amiss here. Are you sure you measured correctly?
Old 03-14-2024, 01:35 PM   #26
Bored&Stroked
Yeah, from the picks, looks like the piston is above the deck to me? I wonder how tall the dome is - should be about .187 above the deck. I'd also measure the heads - they should have the same dome shape and almost the same depth. Then, with a .050 or so head gasket, the squish should come in at about .050 . . . with a bit of milling, you can then tune it.
Old 03-14-2024, 01:43 PM   #27
Ronnieroadster
Ronnieroadster's Avatar
Piston looks fine no issues there from the picture. Would be nice to see the thickness of the putty when its cut in the center and then measured with the vernier. The Orosco heads may be domed at a radius different than the Ross pistons. Older cast pistons such as Jahns as an example were definitely a different dome radius than today forgings.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Old 03-14-2024, 02:33 PM   #28
flatjack9
flatjack9's Avatar
The block has been relieved.
Old 03-14-2024, 04:52 PM   #29
Tim Ayers
Jack,
Judging by the chatter marks and the straight shot, it appears to me to be a factory relieved block.
Old 03-14-2024, 05:24 PM   #30
Ronnieroadster
Originally Posted by Tim Ayers View Post
Jack,
Your right Tim its certainly a factory relieved block.
