09-04-2013, 10:59 AM | #1 |
Removal of Oil Pump Idler Gear Shaft
I am trying to remove the oil pump idler gear shaft. How is this done? I see the idler gear shaft is drilled and tapped, Do we thread a bolt into the shaft and use a pull handle to remove? HELP!!!!
09-04-2013, 11:47 AM | #2 |
Re: Removal of Oil Pump Idler Gear Shaft
A slide hammer with a 3/8 course stud in the end will clunk it right out. Walt
09-04-2013, 11:53 AM | #3 |
