Old 11-15-2023, 10:48 AM   #41
kirkf
kirkf's Avatar
Default Re: '40 brake lamp switch / master cylinder issue?
Thanks!
Kirk
1953 Ford F100
1950 Ford F47 (F1)
1940 Ford Pickup
kirkf is offline   Reply With Quote
Old 04-24-2024, 04:42 AM   #42
mike42
mike42's Avatar
I’m encountering the same problem and was wondering who sells the better switch than NAPA ?
THX
mike42 is offline   Reply With Quote
Old 04-24-2024, 06:56 AM   #43
Kube
Kube's Avatar
THX
Mike, see post #25. If you want me to search the exact switch product number, let me know.
Old 04-24-2024, 07:17 AM   #44
mike42
mike42's Avatar
Okay thx
Old 04-24-2024, 07:20 AM   #45
mike42
mike42's Avatar
Kube what store did you buy it from. I’ve heard not so good things on Napa and I think the new one I bought is no good too. Thx…..
Old 04-24-2024, 12:23 PM   #46
Ggmac
Just a test idea . If the swith is npt cant we just hook it to a grease gun and pump a very little . Or make a zerk fitting to the correct brake light switch thread . I know you’d have to rinse out the grease but it would identify a bad or good switch . If bad , no need to clean out the old grease .
Old 04-24-2024, 12:35 PM   #47
Kube
Kube's Avatar
Like you, two from Napa that were poopy.
Amazon:
WQSING Hydraulic Rear Brake Light Switch DS-272191 Compatible with Harley Davidson Sportster Softail Touring Dyna Super Electra Glide Road King FXR Deluxe Fat Boy Low Rider Heritage 72023-51A
Old 04-24-2024, 12:36 PM   #48
Charlie Stephens
Originally Posted by V8COOPMAN View Post
Kube never even hinted at SILICONE brake fluid! Where the heck did that come from?
Coop
Silicone brake fluid goes through switches fast and going through 3 switches makes it a logical possibility. It is the first thing I thought of and I would have posted it but someone else already had.
Charlie Stephens
Old 04-24-2024, 08:52 PM   #49
Kube
Kube's Avatar
Charlie Stephens
Charlie, going through three new brake switches in the course of three days? Not likely even if silicone fluid were involved.
Nope, just bad switches right out of the boxes.
Old 04-25-2024, 07:33 AM   #50
Mart
Mart's Avatar
I noticed that ford cortina about 1967 uses a 1/8 npt switch. Rockauto carry them. They have spade terminals rather than round but might represent something worth trying. One brand has a hex body which might represent a different manufacturer than the heavily pressed body of the replacement early ford type switches. I have had some failures too and have adapted mech switches.
Old 04-25-2024, 07:59 AM   #51
pistonbroke
I with you Mart. I hate to crossbreed stuff as some of you know, but the mechanical switch that GM used on all the old five window (47 - 54) pickups works very well on my 41 pickup under the floor and out of sight for the most part. Having bright good working is a huge safety factor so this seemed acceptable to me as I drive mine every chance I get. The added bonus is you can flash your brake lights without actually applying the brakes. Tim
Old 04-26-2024, 05:38 AM   #52
aussie merc
aussie merc's Avatar
guys over here are changing to the switch from Harley Davidson they arnt cheap but they work
aussie merc is offline   Reply With Quote
