01-22-2012, 06:03 PM | #1 |
"Blowby oil container"
Some time ago I complained about oil coming out of my oil fill tube. So someone on the Barn suggest this solution. So thought I would post a picture. It works, keeps oil from getting all over everything.
http://69.61.21.195/forum/attachment...1&d=1327273319
Fred Kroon 1929 Std Coupe 1929 Huckster |
01-22-2012, 08:25 PM | #2 |
Re: "Blowby oil container"
Looks like you may need some new rings.! Something to do this winter in wet Oregon!!!
www.whidbeymodelaclub.com |
01-22-2012, 08:49 PM | #3 |
Usually that forces the oil out the rear main.
01-22-2012, 08:58 PM | #4 |
You guys are correct. I think I need a complete rebuild of this engine. Glenn you are correct. It does throw a lot of oil out the rear main into the flywheel cover and on the ground when I park it. But for now this fix keeps the inside of the hood so oil does not get thrown around inside anyway.
Afraid I will have to find someone to rebuild the engine. If I did it, it would be worse that it is now. I have a guy that did my huckster so I think I will wait till spring to pull the engine and see where I go from there. Thanks for the comments. I just thought this "unorthordox" way of doing a fix like this would "pull someones chain".
01-22-2012, 09:38 PM | #5 |
I have run into a similar problem years ago from too many RPM's with oil blowing back on the fire wall and starter and solved it with a larger breather tube added more baffles and a foam filter inside a "O" ringed cap. works great and looks great to boot and never a problem again.
Building Horse Power -- |
01-22-2012, 09:58 PM | #6 |
1921 Runabout 1930 Tudor Early 1930 AA Speed costs money. How fast do you want to go? |
01-22-2012, 10:02 PM | #7 |
Thanks guys for the ideas. Your ideas are more of a long term fix that my old sock method.
01-22-2012, 10:17 PM | #8 | |
Ha, ha...that's funny ! I'm one who suggested this 'solution' in the past. BUT...the sock (actually partial) was to be loosely placed between upper baffel and cap...and occasionally looked at/changed. Since my engine has finally seated and solved the problem, for me, no longer need the sock trick....except for HIGHER rpms. Actually, I replace the sock with every oil/filter change. Your setup looks purdy tho BTW- even with a 'good' engine, I found that only filling crankcase 'halfway' up dipstick (between full/and end of stick)....also helps the overall situation. Last edited by hardtimes; 01-22-2012 at 10:19 PM. Reason: add.. |
01-22-2012, 10:18 PM | #9 |
i use a K&N filter .............. steve
V4f |
01-22-2012, 10:47 PM | #10 |
29 Red Rocket,
Where did you get the bigger breather tube ? |
01-22-2012, 11:07 PM | #11 |
Hey Steve,
Yup, mine has a K&N on the filler also, as you can see in my avatar! Last edited by hardtimes; 01-22-2012 at 11:08 PM. Reason: add... |
01-22-2012, 11:11 PM | #12 |
01-22-2012, 11:19 PM | #13 |
Hardtimes,
Thanks for the info, I appreciate it. Talked to him on the phone a few times and he has always been most hopeful. |
01-23-2012, 09:39 PM | #14 |
Steve, A K&N filter on the oil filler tube? What does that look like? Which filter?
Fix it like you know you're gonna drive it. |
01-23-2012, 11:01 PM | #15 | |
Hello Fred, If you do not know about Bill Barlow (541) 389-2694 (Oregon) for engine rebuilding, give him a call. He is in Bend and is one of the best!! PM me if you want more information about getting the job done. |
01-23-2012, 11:23 PM | #16 |
Any problem with pushing oil out the rear main from this setup?
Oklahoma City Model A Restorers Group. |
01-24-2012, 09:21 AM | #17 |
Instead of steel wool you might try the Choir Girl Brass available in any grocery store cleaning section. It never rusts and if a piece goes down the tube it will do less harm than steel wool !
Wayne |
01-24-2012, 12:20 PM | #18 |
Thanks Ben. I have used a guy in McMinnville that did a good job on my huckster. But will check into the Bend fellow.
01-24-2012, 10:20 PM | #19 |
The engine can vent easier if you use the larger breather tube & cap from a late 32-34 B engine.
01-25-2012, 12:51 AM | #20 | |
I also worry about small pieces of steel or copper falling into the oil pan so it seems to me that one of the plastic "Chore Boy" pads would work just as well and less chance of damage if a piece falls into oil pan. Last edited by Benson; 01-25-2012 at 12:00 PM. |
