06-24-2019, 07:55 PM | #1 |
hmmm no headlights on a 31
no headlights high or low on a 31 coup/ speedster tail lights work. the wireing harness is / was new a couple years ago. everything worked fine. ive done a quick look but see hnothing wrong. I have tail lights. brake lights
06-24-2019, 08:47 PM | #2 |
Re: hmmm no headlights on a 31
Try connecting a ground wire to the headlight and see if that fixes the problem
06-24-2019, 09:31 PM | #3 |
well they are bolted to the frame on this lil speedster, so I know they are grounded
06-25-2019, 05:37 AM | #4 |
I had all of the lights go out on my '28 Tudor last night. The PO had installed a fuse right at the alternator output. The fuse itself was OK but the holder was toast. I bypassed it and drove home. Did the job properly today.
06-25-2019, 07:53 AM | #5 |
06-25-2019, 08:16 AM | #6 |
06-25-2019, 01:34 PM | #7 | |
Bill Kiss
06-25-2019, 06:17 PM | #8 |
well I took the wire harness off the bottom of colomb and cleaned things up and presto ! lights
06-26-2019, 03:30 PM | #9 |
Nice!!!!!!!!
06-27-2019, 02:34 PM | #10 |
Bad grounds can happen. I know that well.
Bad ground at the battery end can do that too.
<Link> This is how we roll<Link> "I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob Outcasts rules of old cars #1 Fun is imperative, mainstream is overrated #2 If they think it is impossible, prove them wrong #3 If the science says it impossible you are not being creative enough. #4 No shame in recreating something you never had #5 If it were not for the law & physics you would be unstoppable |
